Results 1 to 10 of 10
BANNED BANNED BANNED
- Jul 2003
- 2,267
January 3rd, 2007 06:35 PM #1planning to diy the valve seal.
ano bang magandang brand gamitin para sa installation ng cylinder head gasket??? sabi sa ibang thread ndi daw dapat silicone sealant.
any advice???
tnx!!!
January 3rd, 2007 07:42 PM #2
Tsikot Member Rank 5
- Nov 2003
- 3,849
- Jul 2003
- 2,267
January 9th, 2007 05:02 PM #4ah ganun ba!!! so now i know!!!
so kahit wala ilagay ndi magleak basta lapat yung head sa gasket at block.
bakit yung mekaniko ko dati may nilagay na brown substance. the second time, gray naman (threebond ata yun).
tnx!!!
- Sep 2004
- 132
January 10th, 2007 05:33 PM #5yung mechanic ko ang pinabili sa kin dati gasket shellac.
bilin pa nya "yung red yung takip" hehe
- Jul 2003
- 2,267
January 10th, 2007 05:42 PM #6kahit ba luma na kotse ndi nilalagyan ng selant or shellac ang head gasket para sure na walang tagas????
gusto ko lang manigurado mga sir!!!
tnx! ulit.
January 10th, 2007 08:02 PM #7
- Sep 2004
- 59
January 11th, 2007 03:59 AM #9
Correct! Big no no ang paglagay ng RTV pag cylinder head gasket na ang pinag uusapan. Grabe kasi ang init and pressure na iniinda ng cylinder head gasket. Any RTV or gasket sealant na ilagay ay siguradong lulutong pag tumagal, and yun ang pwede maging tagasan ng oil papasok ng cylinders (galing sa oil valleys).
What I can recommend for DIY'ers is a very thin and even layer of oil na ipahid both sides. any excess will seep out naman once you bolt your cylinder head using a torque wrench.
ang shellac na gasket sealant, mare-recommend ko sa crank case gasket, same with the valve cover gasket. Had a bad history when it comes to silicone gaskets, maski hi-temp pa siya.
January 11th, 2007 08:34 AM #10
Depende sa conditon ng head, kung bagong refaced ung head hindi na kailangan lagyan, langis o grasa lang para gumanda ang lapat nito. Kung medyo alanganin ka sa gasket areas lagyan mo ng shellac kalimitan sa mga mekaniko ang gumagamit nito pag hindi nareface at overheat ang problema ng makina disadvantage lang nito pag kinalas uli mahirap alisin at linisin.
Never for RTV sa head gasket.
Straight edge at feeler gauge naman ang pagcheck ng cylinder head for warpage in several locations.
high idle RPM at engine start
