Results 1 to 2 of 2
    Feb 2010
    bros hi,
    i have a problem with my altis' passengers' window on the left for quite a time....now it is closed permanently because when i pushed down the switch it will not move a bit.
    do i have to bring this problem to Toyota? or is it advisable to just make the repair in a private shop.
    bros, can you recommend a shop where i can bring the car for window repair? i am from Antipolo City.
    thanks guys
    Feb 2009
    Quote Originally Posted by Bisshao View Post
    bros hi,
    thanks guys
    do you mean left rear window? for future reference, the doors are numbered front to rear, left to right; hence, driver's door is #1, right front passenger door #2, left rear passenger door #3 and the right rear door #4. same falls true with tire numbering. the system is used on aircraft too.
    if the offending window is the #3, it maybe because this window is hardly opened/closed unless you exercise them at least once a month.the motor might just be stuck and need tapping with a light plastic hammer and relubricated.
Altis Power Windows
