Results 1 to 2 of 2
February 25th, 2010 02:38 PM #1
bros hi,
i have a problem with my altis' passengers' window on the left for quite a time....now it is closed permanently because when i pushed down the switch it will not move a bit.
do i have to bring this problem to Toyota? or is it advisable to just make the repair in a private shop.
bros, can you recommend a shop where i can bring the car for window repair? i am from Antipolo City.
thanks guys
February 25th, 2010 05:42 PM #2
do you mean left rear window? for future reference, the doors are numbered front to rear, left to right; hence, driver's door is #1, right front passenger door #2, left rear passenger door #3 and the right rear door #4. same falls true with tire numbering. the system is used on aircraft too.
if the offending window is the #3, it maybe because this window is hardly opened/closed unless you exercise them at least once a month.the motor might just be stuck and need tapping with a light plastic hammer and relubricated.
Maraming Salamat :)
