Page 1 of 3 123 LastLast
Results 1 to 20 of 60
    Jun 2003
    Hello diesel peeps,
    Anyone here knows where to get airhorns, ones that are heavy duty and with compressors.
    Any idea how much it costs? :beard:
    Truck parts supply along Rizal Ave. or A. Bonifacio Ave. will surely have this in stock. What kind of vehicle will this be attached to? Some mechanics modify the alternator vaccum assembly for air supply instead of addtional load from a compressor unit. Ordinary plastic pairs are sold for a couple of thousand pesos. The stainless long air horn is around 3-5K. Some compressors are sold separetely ranging from 800-3K.
    I have tried those cheapo air horns before, it comes with its own small compressor. Not much of help came when every electrical surge from starting an engine. The compressor usually got stuck and won't blow air. I think I still have that set somewhere in our garage.
    HTH
    Jun 2003
    thanks
    ill try to check it out
    planning to put it in a 91 model pajero. will it fit inside the engine bay?
    ung bagong model ng stebel na available sa shop namin..
    NAUTILIUS ang name...same tone as airhorns...IN A SMALL PACKAGE!!!
    super lakas......i swear..kung hindi ka malakasan..libre kita ng coke....herhehrehr
    Feb 2003
    Glenn ang hina ng horns. kulang na kulang.
    coke ko?
    Jun 2003
    Glenn
    mas malakas ba sya sa bosch europa?
    yun kasi currently gamit ko...
    mejo marami kasi gagawin pag air horns based on research i did.
    im planning to get another pair of europas na lang, meron din ba kayo nun?
    will the nautilus sound better? nver heard of it pa... but stebel is good got stebel fanfares on our revo
    Jun 2003
    oh btw how much are ur nautilus? with install?
    Sheep::: The plastics type will definitely fit under your hood, but I doubt if the long stainless ones will. Dami ko nakikita mounted above the hood like on the jeepneys. Imo, go for the Nautilus, you'll end up with a budget wise option and less headache.
    GlennSter::: Parating ka ulit ng horns, naunahan ako ni Rod & Bubbles. :D
    Jun 2003
    ungas
    plano ko nga yung stainless e kaya nga parang nagaalangan ako kasi di ko maisip kung saan ko itatago. yes ill try to check if ok nga yung nautilus ill just compare kung ano mas ok. nautilus or another pair of bosch europa.
    btw anong horns yung pinaparating mo ke glennster? mukhang maganda ata yun a
    rod..sabi nga ni kuya ronald..mejo mahina daw ung iyo.....sa wiring siguro yan....chekc mo ulit..sakin ang lakas talaga pag tine test namin eh..
    ungas..may parating na 3!!!!
    980 (discounted na yan ha...) ang nautilius..1
    Jul 2003
    Actually kailangan ko dalawa para ma 24 volts ko. tanong mo naman kung pwede order 24volts
    Glennster,
    papaano tunog nun nautilus? para ba ito MACK truck? un kasi rin ang hinahanap ko e...
    Reserve 1 for me before Bubbles buys it out again! :D
    glennster,
    inquire ako last friday ng stebel wala na nga raw stock nakuha na ni rod.
    "Glenn ang hina ng horns. kulang na kulang" from rod tama ba post ni rod mahina or ng hingi lang to ng coke?
    nag dalawang isip tuloy ako kung fiam or stebel kunin ko........... or may effect ba ang supply (current) dito to get the exact sounds. sa hilander kaya makuha un lakas ng sound na sinasabi mo?
    thanks sir
    Maganda if you have it wired directly to the battery using high quality wires. Swak na swak.
    Gusto ko Bosch bling bling, eh. hehehe. Ipon muna siguro.
    Jul 2003
    GUys nanghihingi lang ako ng coke. Tumabi kayo sa bus. exacto ganun ang tunog. ganun din ka lakas.
    glenn, 2 battery 24volt system ako. I get power for all my 12 volt appliances form 1 battery so mabilis nadrain yung isang batt. mahina alang yung batt kaya mahina horn. kaka charge ko lang, lakas na ng horn. Me?! mali mag wiring? malabo yun. haha yabang.
    Jul 2003
    Otep, may horns ako na gusto mo.bosch.
    Jun 2003
    mas malakas ba yang nautilus sa bosch europa (metal)?
    Just to clarify, yung Stebel Nautilus is shaped like a conch shell/nautilus (kamukha ng Fiamms ng mga Ford), but bigger? Tapos P980 all in na? Or plus pa for installation? Or meron pang kelangang bilhin na ilang piyesa?
    Thanks.
    Jun 2003
    imm29 nadinig mo na ba yang nautilus na yan? dami nagsasabi maganda e lakas daw
air horns
