Results 1 to 7 of 7
September 21st, 2007 02:48 PM #1
I only experience this during cold starts in the morning.
I notice that pag engage ko sa reverse after initial startup, biglang magrerev ang engine causing it to "thud" reverse.
I don't experience it after the engine is warmed up specially when AC is on.
Ano kaya ang problem? Sabi nila yung "thud" experience might be due to worn out engine support?]
Car btw is an Altis '03 AT
TIA.
September 22nd, 2007 01:32 AM #2
I also experience this with our 2000 Corolla.
Mag thud siya every morning when backing out the garage.
I think the reason for this is the car operates at a higher RPM when engine is cold until it heats up to the normal operating temperature.
What I usually do is shift it to D first then to R.
Tsikot Member Rank 5
- Nov 2003
- 3,849
September 23rd, 2007 03:29 PM #3yup, probably nga cause mataas yung idle when you just turn on the engine.
September 24th, 2007 07:13 AM #4
Thanks Augustus, Speedyfix. Problem is I don't experience this with our other corolla '02 model.
*Augustus, I might try the Drive then Reverse technique.
*Speedy: Might have it checked na din since nearing my 5tkms PMS..isabay ko na.
Tnx.
September 25th, 2007 10:23 PM #5
wow ako din ganto with my lancer 97 A/T specially pag umaga talaga pero tuwing umaga lang ito nangyayari, pero ako sa "D" ko engage never tried pa sa "R" always park my car pa reverse e
*Djerms update po ha pagkacheck up niyo baka makatulong narin
September 26th, 2007 09:13 AM #6
i experience the high rev but no 'thud', medyo slow lang mag-engage yung transmission. maybe the fluid hasn't filled the converter yet?
- Nov 2003
- 3,849
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
