what vehicle do you have?
if you already have a pull fan, you can augment airflow through the condenser and radiator by adding a push fan and maybe a scoop or air dam below the radiator to direct ram air through both the condenser and radiator. similar to the '90's camaro, it is prone to overheating if the scoop is missing from hitting parking lot curbs
Mit Adventure boss...
it doesn't have an auxiliary fan yet for the condenser,,, kaya mukhang high pressure siya pag na traffic....
should the air flow be going into the condenser or sucking air out for better cooling?
thanks....
