Results 1 to 5 of 5
June 11th, 2007 09:16 PM #2
Anti-lock Braking System ata yan. So that you can still control the car after a hard brake AFAIK
June 12th, 2007 07:57 AM #3
Keeps the brakes from locking under hard braking or slippery conditions. AFAIK, the '98 Lancer GLXi doesnt have that.
June 12th, 2007 08:09 AM #4
If your car is eqiupped with ABS, you can still steer your car even if you make a sudden hard brake.
June 12th, 2007 11:07 AM #5
Not familiar with lancers, but what you can do is follow the steel lines from the brake master. If it goes down right away- wala. If it goes to a sort of a box on either side of the engine cockpit and divides into 4 steel tubes chances are ABS yon.
Automatic po Sir
