Results 1 to 3 of 3
    Feb 2006
    mga sir need ur help,
    ano ano po ba yung mga kailangan gawin/palitan pag nag general o/h?naghalo po kc yung oil and water during an oveheat problem while travelling at expressway.
    mga magkano po kya yung aabutin ng labor?machine shop fees?gaano katagal ggawin?
    yung mga parts po ba pwede nyo ko tulungan mabuo?and price if possible?balak ko po kc tsek kung kya ng budget e.pag hindi tengga n lng muna } wala po kya epekto to sakaling stock muna sya ng ilang buwan habang nagiipon p ng funds}
    Ride po is 97 galant , 4G92 po yung engine
    help po mga sir medyo sakit n ulo k kaiiisip e
    tsaka any cavite people here that can recommend magaling n mekaniko to do the job?
    salamat po mg a sir
    Aug 2004
    Depende talaga sa problema. The prices have increased since the last time I had an overhaul, so baka iba na rin yung cost.
    I'd say 15,000 - 20,000 (remove head (used to be 6k), machine shop (dunno), replace head and gaskets) or 40,000 up (major work done on internals).
    You won't really know how bad it is until you open the engine. But if you didn't run it long after the overheat and the pistons didn't get damaged, di naman siguro ganoong kamahal.
  3. #3
    kung gagastos ka ng 50 thou mahigit, kuha ka nalang ng 4g63T or 6a12TT.. pwede din para matipid parin 4g92T nalang.
    ang downside ng overhaul kasi, kung maibabalik ng tama sa specs ng machine shop/mekaniko..
    my 2c-turbo top overhaul costed me 12thousand(6000 machine shop, NOK valve seals, at original toyota head gasket..+900 sa cleaning of injectors+4000 mekaniko+1100 misc items-sealants, etc..) nakasave pa ako nyan sa valves, valve guide, injectors...
    pa- quote mo muna, ang genral overhaul, then hanap ka ng makina sa banawe(sama mo mekaniko mo) then quote mo magkano mounting/salpak sa sasakyan..plus ka ng 1000 para sa LTO-change engine...
Top ^bottom overhaul?
