hello...
advice naman po..
nagoverheat kanina yung makina ko..
then dinala sa talyer...
sabi kailangan daw palitan ang water pump kasi may tagas..
then magpapalit na rin ng radiator hose at gasket...
tapos kailangan daw ng bagong cylinder head kasi may bula daw, parang leak ata dun nung pinalitan before yung valve seal...
ndi ko sure kung dapat bang ayusin yung leak.. which means magpapalit ng ng cylinder head..para maayos ang oeverheating problem?
the quote is 10K for this whole problem..is it reasonable?
please advice..thank you..
