Results 1 to 10 of 12
February 28th, 2008 09:11 AM #1
car is city idsi,
2nd hand car.
was going to do the my first tune up, no manual,
under the engine cover,
i saw only four sparkplugs...i've read here na it has 8 sparkplugs?
does it literally have 8 sparkplugs? or 4 lang talaga?
also, the mechanic said, this does not need the timing check like the old cars?
if it does not need the timing, what does it need?
thanks.
Tsikot Member Rank 4
- Jun 2006
- 2,605
February 28th, 2008 10:11 AM #2I'm no expert. As far as i know, idsi does have 8 spark plugs and its timing is controlled by the ECU.
February 28th, 2008 10:53 AM #3
I believe it's 4 in the back near the firewall, and 4 towards the front.
It's a good idea to get a service manual too if you can find one, or at least an owner's manual.
February 28th, 2008 11:07 AM #4
thanks,,will try and find it..if it's near the firewall, eh di not that accessible sya? sige..will see it later.
and also, the ecu timing? how does it work? sinasaksak sa computer? or using the light din? is it included in the regular tuneup?
February 28th, 2008 11:11 AM #5
No I mean near the firewall - towards the rear.
No idea on ECU timing though. Possibly reprogramming to get the best timing for the dual plugs. Why not take it to the casa, then observe them at least for experience at least you know. Then after that on consecutive tune ups a few years down the road you'll know how to do it.
February 28th, 2008 11:51 AM #6
As far as I know wala ng timing yang IdSI, para mga new generation VVTI ng Toyota. In my Innova wala ng timing, it is self adjusting done by the ECU. Just replace the spark plugs and off you go. You will only have the the ECU reprogrammed if you feel have problem with emmissions and fuel knocks or power adjustments.
Try to read the metal plates under the hood of your Honda, I'm sure it was written there that "no timing/adjustment needed" It should be written where you can find the spark plug gap information.
February 28th, 2008 11:56 AM #7
big help sir!
thanks!
finding the other four sparkplugs na lang..hehe...
Tsikot Member Rank 5
- Nov 2003
- 3,848
March 2nd, 2008 10:53 AM #8you will find the other four towards the rear partially hidden by the intake manifold. look for the ignition coils lang to find where the plugs are.
March 4th, 2008 11:13 AM #9
thanks! found them. 8 nga. 4 on each side. meron sa meh back part, near the wall. magastos pala. bought 80 pesos sparkplugs..sa lourdes autosupply. open sila pag sunday. laki pala natitipid pag u do the tuneup urself.
so..if the car doesn't have problems..d ko na kailangan pa timing check?
March 4th, 2008 12:31 PM #10
2025 Suzuki Dzire Hybrid Ice Skating Audition — Sponsor Us, Suzuki! AutoDeal
4th Gen Suzuki Dzire
