Quote Originally Posted by rickytaz View Post
4d56 turbo , timing problem , after setting the timing marks on the crank diesel pump and cam i turn the motor over one full turn and realign the crank timing mark but the cam and injector pump are 180 degrees out , i tun the motor over one more turn and all the marks in the correct place , does any one know what is causing this problem and how to fix it please
Normal lang yan.
Normally ang can at yung injection pump ay gumagana half the speed of the crankshaft. hindi na silang lahat ay pare-parehos.
For example. if the crankshaft rotates at 1000 rpm then the cam and injection pump only rotetes at 1/2 the speed of the crankshaft.
kung di m pa ma get's, imagine yung cycle sa makina. d ba ang piston ay tumataas at bumababa ng dalawang beses para ma complete ang isang combustion cycle. at ang cam naman ay isa lang dahil ang cam ay makagawa na ng i combustion cycle i 1rev. which means mayroon na ng intake at exhaust ang nangyayari sa isang cycle ng cam. same with the injection pump.
