Results 1 to 4 of 4
November 16th, 2004 11:38 AM #1
after opening the rocker arm cover of my engine to fix an oil leak, i found out that a portion of the camshaft had some scratches. is it advisable in the long run to replace the camshaft? any idea how much this would cost? any recommended brand as replacement instead of OEM?
thanks in advance peeps! wheew, butas na naman bulsa ko
- 3,754
November 16th, 2004 06:32 PM #2Last Sept nag palit ako ng cylinder Head dami ko nakita sa banawe rocker arm at camshaft? I got it for 8K assembly na sya. with rocker arm. kung Camshaft mas mura lang stimate ko mga 4K may ma bibili kana
November 16th, 2004 07:17 PM #3
mag surplus ka dude. mag blumentritt ka muna. pag wala talaga dun ka pumunta ng banawe. reminder mag shorts at tsinelas ka lang kung maari butas na t shirt hehehehe para maka mura ka
November 17th, 2004 09:55 AM #4
thanks guys.
is it advisable to reface na lang the damaged portion of the camshaft and yung katapat nyang rocker arm? tutal slight lang naman ang scarring.
high idle RPM at engine start
