Results 1 to 15 of 15
    Jun 2006
    Ano kaya cause? Normal kaya to?
    That's strange, san mismo mainit? Kasi goma yan eh.
    Jun 2006
    sir david: simula dun sa may nakalagay na P-R-N-D-2-1 hanggang sa lever mainit lalo na pag long drive.
    ano kaya dahilan?
    Feb 2003
    have you checked your a/t fluid lately? baka kulang na. most probably drain and replace your a/t fluid.
    Aug 2004
    AT fluid yun. The heat probably comes from ATF heating up in traffic.
    It's easy to check your fluid level... the dipstick is low and on the left side of the engine bay. Also check for impurities and contaminants.
    Tingin ko din lack of ATF or expired na ATF mo...
    Or pwede din barado ang oil cooler mo?
Sobrang Init ng AT Lever
