Results 1 to 10 of 12
- Nov 2002
- 748
October 15th, 2003 05:47 AM #1Plan ko magpalower ng car pero may mga nababasa ako na kailangan daw ang camber kit? It's a must ba for lowering a car?
Ano naman iyong camber correction? Nag canvass ako sa talyer sabi nila daw camber correction daw after lowering ng car...
Any opinions/experiences?...ala akong idea kung ano itong mga to.
October 15th, 2003 10:26 AM #2
Depends on the car. pag kasi binababaan ang ride height(lowering) tendency ng camber ay mag-"toe-in" o kaya "toe-out" in other words, improper wheel alignment. meron mga kotse na may camber/toe adjustment meron ding wala. dun mo kailangan ng camber kit.
btw anu b kotse mo?
- Nov 2002
- 748
October 15th, 2003 11:59 AM #31997 pizza pie lancer ang sa akin...pacheck ko kung may camber adjustment na to..
thanks!
October 15th, 2003 12:11 PM #4
kailangan mo ng camber to avoid future headaches , not necessarily na kailangan mo agad as soon na ni lower mo . pero for future references na magtataka ka na bakit butterfly yung gulong mo or kahit na nag pa alignment ka na ay di siya maayos , nasa cambers mo yan . if ur tight sa budget , u can get maybe after a year or 6 months to bago maubos ang gulong mo na di pantay .
- Nov 2002
- 748
October 15th, 2003 01:22 PM #5dsm...camber kit or camber correction lang ang kailangan or both?
thanks!
- 35
October 15th, 2003 03:44 PM #6Guys, singit lang ha :-)
Saan maganda magpa-adjust ng camber? Lancer itlog...
Thanks
October 15th, 2003 04:11 PM #7Originally posted by bustmybrain
Thanks
October 16th, 2003 04:37 PM #9
DSM question lang,
even if the drop of the car is just around 1.25-1.5 eh kailangan pa din ba ng camber kit?
October 17th, 2003 04:23 AM #10
based on my own experience, malalaman naman ng shop kung kailangan mo ng camber bolt dahil masyadong negative camber ang alignment. In most cases, less than 2.00" drop doesnt require a camber bolt specially kung maganda ang springs mo at hindi nag-sag. having a negative camber on the rear is not necessarily bad if you wanna reduce understeer. (refer to another thread talked about the alignment settings) Sa daily driver, -1.00 camber isnt all that bad. I have a -1.00 front and -0.75 rear
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
