Results 1 to 10 of 15
October 14th, 2003 01:30 AM #1
bakit pag pasok ko ng 1rst gear at dahan dahan kong binibitiwan ito sabay tapak sa accelarator ay napakalakas ng nginig ng makina ko? sa second hanggang 4th naman ay wala. ano kaya sa tingin nyo guys? my car is corolla 92 xl.
October 14th, 2003 08:52 AM #2
Engine vibrations on 1st gear... hmmm tough to diagnose without seeing the unit. It could be engine supports or your clutch system could have foreign deposits( it could also be at the transmission).
October 14th, 2003 11:03 AM #4
kelan ba lumalabas ang sakit? initial use ? (sa umaga) or pag uminit na makina? o pare pareho din?
October 14th, 2003 11:36 AM #5
kahit mainit ang makina, ganun pa rin. pare pareho lang. btw, almost 6 years na sa akin ang kotse at wala pa akong napapaayos sa clutch system ko.
sobra lakas ng nginig, parang mawawasak ang harap ko.
- 71
October 15th, 2003 03:22 PM #7oo nga... ganyan din yung sa akin e. early symptoms bago tuluyang magsliding.
October 16th, 2003 03:46 PM #10
Clutch sliding occurs when you depress to change gears then power is not transferred as soon as you release your clutch pedal. This is more obvious when shifting from 2nd-3rd-4th gears.
Pag pinabayaan nyong sliding yan, katagalan di nagagana ang clutch at di nyo maiipapasok ang kambyo, kahit primera.
Kung walang spare tire, invest on a Inflator kaysa sa sealant. Inflate the flat tire +10 psi than...
Liquid tire sealant
