The 4x4 SportContact is Continental Tire's Street/Sport Truck Summer tire designed to offer ultra high performance tire capabilities to the drivers of performance pickups and sport utility vehicles. Used as Original Equipment on the Porsche Cayenne S and Cayenne Turbo, the 4x4 SportContact is designed to combine the tread design of Continental's original ContiSportContact Ultra High Performance Summer tire with the large rim diameter sizes appropriate for light trucks. The 4x4 SportContact is not intended to be driven in snow.
The 4x4 SportContact features an asymmetric tread design with large outer shoulder blocks to enhance cornering stability and control. A continuous center rib enhances steering response and high-speed stability while wide circumferential and lateral grooves channel water to enhance wet traction and reduce the possibility of hydroplaning. The tire's structure includes two steel belts reinforced by spirally wrapped polyamide over a rayon cord carcass to enhance handling and high-speed capability.
