Results 11 to 20 of 23
March 12th, 2009 12:17 AM #11
- Nov 2008
- 99
March 12th, 2009 09:34 AM #12bro ang prob mo lng ung rocker gasket.. ganyan din ang naging prob ng sentra ko.. maliit lang na gasket un sa ibabaw ng engine... nakabukod un sa overhead gasket.. YM mo ako pag may tanong ka.. ez4u2564*YC
March 12th, 2009 01:01 PM #13
Kidding aside, sa tingin ko you need to replace your mechanic... that's what I did when my former mechanic failed to put an end to my Maxima's problem... white smoke din.
Valve seals, piston rings, gaskets . . . lahat ito ay pwedeng pagmulan. Pero kung minsan, yung mekaniko ang problema: choice of parts, expertise, at common sense.
Save money, time, and effort. Magbago na!
March 13th, 2009 05:02 AM #14
ganyan nangyari sa 96 liteace ko. buti na lang magaling mekaniko ko. nakuha sa isang trabaho lang. almost 2 yrs na, hanggang ngayon ok na ok pa. ang ginawa nya binaba yong cylinder head tapos pina-machine shop. ayun, problem solved!
March 19th, 2009 07:28 PM #15
funny but oftentimes true.
going back to arvy's problem - white smoke could indicate burning oil and there are many possibilities kung bakit. from loose gaskets, to worn out valve seals and piston rings. kung bago bago mo pa lang na-experience yan wag mo nang patagalin pa. pa check mo na agad.
- Oct 2008
- 469
September 18th, 2009 05:48 PM #16Q: Normal lang po ba na sa first start is may malakas na white smoke na lumalabas sa tambutso, mga 3mins tumatagal ng pagbuga ng white smoke, medyo malakas?? But pagpinatakbo ko na sasakyan, nawawala na yung smoke and normal na. Sa first start lang may white smoke. Or baka lang po malamig lang panahon ngayon??
- Sep 2009
- 3
September 18th, 2009 09:12 PM #17
makiki-ride na rin po sa thread.. pareho po tayo ng problem sir, encountered ko na rin ganyan sa 94 sentra ko. pag start makapal na white smoke nalabas sa tambutso. mga 10mins na, ganun parin . off ko engine then start ulit, ayun clear na. gastos na naman po ba ito?? help po mga masters.
September 18th, 2009 09:38 PM #18
ganyan rin 95 sentra ko baka naman malamig lang kasi nag gaganyan sentra ko pag umaga yung tipong malamig haha
me nakita ako civic fd nung malamig ganun siya nagbubuga ng makapal na white smoke
i think its normal kung malamig panahon
pero kung mainit ganun parin
ang sabi sa akin me nabuburn yung spark plug na oil (ang oil daw pag naburn produces white smoke)
different naman ito sa black smoke na dahil sa dumi or dahil sa incomplete combustionLast edited by kulotz; September 18th, 2009 at 09:42 PM.
September 18th, 2009 10:24 PM #19
Pag malamig panahon natural lang ang may white smoke na lumalabas at pag nagtagal ay nawawala na rin . Maliban na lang doon sa nakikita natin na habang tumatakbo sasakyan nag bubugaga ng Puting usok. Magandang tips lang ito kung gusto mong malaman kung maganda kondisyon makina mo tignan mo iyong tip ng muffler mo kung medyo maputi carbon ayos iyan .Pero pag basa at black thick carbon hindi maganda ang sunog ng gasolina ng sasakyan mo. Sa gasoline engine ito.
- Sep 2009
- 5
September 21st, 2009 09:55 AM #20Hi, if you have white smoke that comes out the exhaust this means that you have a damaged head gasket.
http://www.cartechhome.com/2009/09/w...st-of-car.html
Monk-owned R53
