Results 41 to 50 of 77
December 12th, 2002 08:55 PM #41
Originally Posted by pajerokid
December 13th, 2002 08:23 PM #42
Boss boybi::: May tendency po maging comfortable yung ride nyo. Nagpakabit na po ako ng bagong coils and shocks. Medyo tumigas but the ride is better, di na masyadong bouncy like the stocks. :D
http://www.pbase.com/ungas/ome
December 13th, 2002 09:25 PM #43
ser boybi::: yung sakin po lumambot yung ride :D i cant recall if the ride went firm at first.
December 13th, 2002 10:01 PM #44
now i'm confused. sir Ungas, pano naging better ang ride kung tumigas sya? :roll:
ano palang nangyari bakit ang dami atang napost? pano ba mag erase? o kaya mga mods paki erase nalang mga duplicate posts. tnx. :mrgreen:Signature
December 13th, 2002 10:17 PM #45
aaaaaaaaahhhh :mrgreen: Yung kay ungas kasi sobrang bouncy coz laspagation na ang shocks nyang luma. so, improvement sa kanya nung naging firm. But if you compare them to stock, definitely mas malambot! :mrgreen:
December 13th, 2002 10:31 PM #46
so would you suggest na papalit ko shocks ko to OME or Rancho? which is better ba?
Signature
December 13th, 2002 10:37 PM #47
boybi,
Kaya po masarap sakyan kahit firmer ang damping settings ng shocks at springs ay dahil mas mataas po ang level of control and lessened ang unecessary movements. Tignan mo yung mga BMW, ang titigas ng suspension pero mas masarap sakyan kaysa sa mga softer-sprung Japanese subcompacts. Kasi pagtama ng bump, absorb agad without wallowing tapos balik agad sa normal position. Controlled ang compression AS WELL AS extension. Most stock suspensions only work well in one direction (usually compression).
December 14th, 2002 09:28 AM #48
It all depends what you may want to call on "better ride". For me, I prefer stiffer ride for more control. Some may opt for smoother, bouncy soft rides which has more roll when making turns. :D
Well said pajerokid, :mrgreen: Laspag na talaga yung shocks ko, as in STUCK in stocks. Ngalay pa yung mga coils, that's why I posted earlier it has bouncy ride. Para akong nakasakay sa tsubibo nasa maalon na tubig. :mrgreen:
December 14th, 2002 12:54 PM #49
so which is better, OME or Rancho? and ang dami atang klaseng Ranchos? ano yun from 1000 to 9000?
Signature
December 16th, 2002 02:23 PM #50
guys,
what's the use of steering damper? what's the advantages of having one installed? Meron bang ganito for trooper?
thanks
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
