Results 1 to 10 of 77
December 1st, 2002 11:29 PM #1
san ok and mas mura magpa suspension upgrade ng nissan patrol para mabawasan ang tagtag?
BANNED BANNED BANNED
- 3,790
December 2nd, 2002 06:39 AM #2sir,
korek me if I'm wrong po....ang modelong patrol have a car-like ride na kasi SUV class na iyan with independent suspensions....
Kung matagtag yung ride mo, baka po masyadong matigas ang tires mo due to high tire pressure or inflation...may be you can reduce it to the lowest allowed pressure....just make sure its within specs kasi malakas pumudpod ng gulong pag mali ang inflation po.
Further, kung talagang matagtag pa rin, suspensions na po talaga (pero ang alam ko OME na ang suspensions niyan) may be you should replace them with Bilsteins or Rancho's. But check with your casa first kung underwaranty pa iyan, because baka mavoid kung papalitan mo basta-basta or kung papalitan mo at hindi mo sa casa ipapatrabaho.
my 2 cents.
December 2nd, 2002 09:51 AM #3
whats the model of your patrol?
i dont think they come from the factory with OME maybe OEM.
- 10,620
December 2nd, 2002 09:58 AM #4just play with air pressure muna.
ako nga satisfied na ako sa strada ko eh
December 2nd, 2002 02:06 PM #5
i have already set the tire pressure to the lowest allowed pressure. compared to our frontier pickup, mas matagtag pa rin yung pickup. gusto ko lang sanang mas iimprove ng konti yung ride. pag kasi kadadrive ko palang ng crv tapos lumipat ako sa patrol nakakapanibago yung tagtag.
Signature
December 2nd, 2002 02:41 PM #6
Malaki po talaga difference ng ride, chassis based kasi ang Safari, not like the crv na monocoque body. Kung gusto nyo po palit kayo ng coils ng Safari nyo, you might wanna try used coil springs para mas malambot. :D
December 2nd, 2002 02:49 PM #7
meron ako nabasa na thread dito regarding suspension upgrade for expedition. pwde din kaya yun sa patrol or meron kayang pang patrol?
Signature
4x4ph.com
- 695
December 2nd, 2002 03:03 PM #8Originally Posted by wildthing
December 2nd, 2002 03:09 PM #9
ano ba pinagkaiba ng front live axle and independent suspension. naguluhan ata ako dun a. :roll:
Signature
December 2nd, 2002 03:36 PM #10
One thing for sure, ang Safari naka coil springs over solid differential both front and rear. Yung Y60 or GQ model has the same underchassis as the new Y61 or GU models. So I may pressume that my coils would fit under your new Safari sir boybi. Di yata binago ng Nissan :?:
high idle RPM at engine start
