Results 1 to 16 of 16
    Feb 2012
    im going to buy a brand new tires, i have 15 inch mags. . and im using 195/55 series tires. . gusto ko sana magpalit ng 50 series tires. . ok lang kya? hindi ba maapektuhan ang performance? or bka hindi ko na maitakbo ng long distance? thanks sa mag iinput. .
    Feb 2012
    nissan series 3, nga po pla oto ko. .
    magiging matagtag ang ride mo at lower ng konti ang clearance mo. bakit mo sir gagawin 50 series? para ba mas maganda tignan? i suggest increase mo width to 205 para ma maintain mo yung diameter at mas maganda kapit sa daan.
    Feb 2012
    manipis na kasi yung mga tires ko bro. kya mgpapalit ng brand new. . kya ittry ko sana mag 50 series tires. .
    pwede yan, yun nga lang, mas mababa ng konti kaya dapat laparan mo para maintained ang height. 205/50/15 bilhin mo.
    May 2011
    you may use this tire calculator to guide you: Tire Size Calculator - tire & wheel plus sizing
    Feb 2012
    so dapat mas malapad. . yung 205? pero kahit nka 50 series tires, pwde pa din ba sa long distance trip mga bro. ?
    Aug 2004
    Smaller tires will change your gearing. You'll be doing 100-200 rpms more at 100 km/h than before, which makes for worse fuel economy but slightly better acceleration. The ride will get a bit worse, the handling a bit better.
    If you're doing it for reasons of economy, don't bother. You'll save more gas sticking with the bigger tires.
    Feb 2012
    parang pabor skn to bro. kasi ang bigat tlaga ng kaha ng b14. . what do u think sir?
    Aug 2004
    Not necessarily terribly matagtag... just more so than 55 series.
    Quote Originally Posted by nuebe View Post
    The difference in weight between 50-55 series tires of the same make and model is a mere 1-2 pounds per tire. If there is any. You're only losing a strip of rubber less than half an inch tall around the circumference of the tire. And worse, if the model you buy in 195/50 is naturally heavier (say, it has a rim protector, since it's a low profile tire), then it may even be heavier, despite being smaller.
    This is not to say lightweight tires are not worth it, but that going down in size is not a guarantee that the tires will be lighter.
    Going series 50 tires will slightly affect the speed reading you will get on the car's speedometer. The handling will feel sharper but you will feel more of the road imperfections too. It might be more tiring to you to ride on series 50 tires. Otherwise, there is no issue mechanically with using series 50 tires on your car.
    I used to ride on 195/55r15 on my corolla but switched to series 55 for a more comfortable ride.
    Feb 2012
    you mean talagang matagtag ang 50 series sir?
    Feb 2012
    mas ok na cguro tlaga ang 55 series. . kahit pa long distance mas kampante ka, . wla na bang mg tatangol sa 50 series dyn? hehe. . bukas na kc ako bibili ;)
    Aug 2004
    Unless you're buying it to go racing... and if you wanted to go racing, you'd upsize to 205/45R16... there's really no point.
    Feb 2012
    thanks bro. i'll go 55 series ;)
    Feb 2012
    thanks sa mga input guys. . kakabili ko lang ng brand new 55 series tires, ngyn lang gabi. . more power sa tsikot. .helpful tlga. . salamat talaga, kayo na ;)
question lang mga bro. about tires
