Results 1 to 10 of 18
- Apr 2009
- 4
October 18th, 2012 12:43 PM #1please help po, i have problem with my 2000 sentra gts. Natunog lagi un belt pag on ko aircon, pro after mga 30 secs nawawala. San po kaya problem nun? TIA
- Feb 2012
- 70
- Feb 2012
- 70
October 18th, 2012 05:28 PM #3pag nag iingay kasi ang belt, malamang maluwag. . try mo muna pahigpitan, . and test mu kung mag iingay pa
- Apr 2009
- 4
October 18th, 2012 06:12 PM #4mahigpit naman po un belt, pinagtataka ko lang everytime na bubuksan ko lang naman ung aircon saka natunog. napacheck ko na din sa mekaniko di din nila alam kasi pagcheck ndi naman natunog, sabi nila pag continous na lang daw un tunog saka ko ipagawa. natatakot lang ako baka maputol un belt or what, sabi naman nila ok pa naman daw un belt. di ko tuloy alam kung safe ba o ndi..
October 18th, 2012 06:53 PM #5
Bearing ng...nakalimutan ko yun tawag yun nag hold ng belt
- Jul 2011
- 399
October 18th, 2012 06:58 PM #6Bearing sa pulley
Tensioner bearing if meron man
Compressor pulley bearing
October 18th, 2012 07:33 PM #7
- Apr 2009
- 4
October 18th, 2012 07:39 PM #8thanks for your reply mga sir.. hirap lang po kasi minsan sa mga mekaniko pag ndi nila naririnig un tunog ayaw nila gawin or icheck sabihin nila ok lang un.. malas ko naman tuwing ipapacheck ko ayaw naman tumunog..
October 18th, 2012 09:06 PM #9
Try mo muna basain ng tubig yun belt ng AC pagnakarinig ka ng sound, pagnawala ingay after putting water it means the belt has problem or need tightening lang pero kung di mawala ingay perhaps bearing is the culprit
Hth
October 18th, 2012 09:25 PM #10
May mga nakikita ako na spray can with the words Belt Dressing. Di ki na nabasa mga details on the packaging, is that something you'd have to use when replacing belts?
So it's another case of "pwede na iyan" once again. It's that kind of thinking that will put...
