Results 1 to 10 of 18
    Feb 2012
    hindi ba basa ng langis?
    Apr 2024
    Quote Originally Posted by nuebe View Post
    Kapag nabasa Ng langis ano dapat Gawin para mag normal mga sir any good advice or suggestion
    Nov 2019
    Quote Originally Posted by Rjmar View Post
    Pa check nyo po sa mechanic, baka need lang linisan at patuyuin if bago pa yung belt.
    If mataas na mileage since na replacean, much better if palitan nalang baka nag degrade na yung quality ng belt after nabasa ng langis.
    Mura lang yung belt at labor for replacement.
    Jan 2009
    What car/engine and what are the issues or symptoms?
    Accessory belts are kinda tough and a little water or oil is not going to significantly affect it. If it's making a noise, find out where it's coming from (as in, which pulley) and check for alignment, wear, or damage. Check also the belt itself, including the tensioner if it's still providing enough tension and dampening. Check the condition of all the idler pulleys, including the one on the tensioner.
    Check also the alternator pulley. When worn out, the internal one-way clutch mechanism (if equipped) will start to slip and give off loud chirping noises.
please help: squeaking fan belt when turning a/c on
