Results 1 to 13 of 13
    Apr 2013
    Hi Sir!
    Baka po may makatulong sakin dito. Problem ko po kasi sa sentra ko, mabaho ung amoy ng usok lalo na kapg start sa morning/ Mahina din po sya humatak, lalo na sa paakyat. Sa rektahan naman, hirap sya maka 100km/hr... Naadjust na po menor nya pati timing, nagpalit na rin po new spark plug and iridium pa po ginamit ko. Asko ko lang po kung normal pu ba ito sa model ng sentra ko? Hindi po ksi ko satisfied sa performance.. Anu po kaya dapat ko ipaayos sa auto ko? Carburator pu ba? Sana po matulungan nyo ko, Thanks in advance...
    Quote Originally Posted by dwardov View Post
    Hi Sir!
    We have the same scenario idol I just had that problem last March 26, 2013.
    Mabaho amoy sa tambutso - with sometimes white smoke, eto patapos na overhaul nya. When the mechanic opened the engine all the burned oil is inside not to mention the carbon.
    Mahina humatak - clutch due for replacement. Same scenario halos ayaw na umakyat ng 90kph.
    I suggest go to the ordinary sparkplugs di naman pang performance or racing yung engine mo kaya baliwala irridium.
    I suggest go to your very trusted mechanic to do the same to your beloved sentra. Ako total amount spent on overhaul alone is 20k labor and materials.
    We have the same engine pala ga13ds.
    Apr 2013
    Sir Brainmafia, ung sakin minsan humahataw naman gang 120kms sa SLEX pro minsan lang mangyari un kapag magaan lang karga ko. Bigyan nyo po ako update ha after maoverhaul ng engine mo kung gumanda na ba takbo at ano na max speed. Tama po kayo, minsan my white smoke din ung sakin. Nakakalungkot naman kung paoverhaulin na pala ung auto ko... Nakalineup pa naman po ito this month ng washover. Anyway, thank you very much sa info na binigay nyo sakin ha. God bless po!
    Apr 2013
    Hello mga idol! Till now di pa rin nsosolve problm ng sentra ko. Mahina ang hatak, up to 110kph max speed lng. Pero ang main concern ko is ung mabahong amoy(amoy gas) inside and outside my car while engine is running. Minsan mausok sa unang start ng makina.malakas vibrate ng mkina.Habang hinahataw,lalong malakas amoy. Khit nkAC o hindi. Ngpalit n ko SP, inadjust n rin timing. Pti fuel/air mixture. Madami na tumingin na mechanic pero paiba-iba sila ng assesment. Mechanic1: need dw linisin carb..
    Mechanic2: bk dw faulty na ignition coil kea mhina sumunog.
    Mechanic3: itop overhaul,adjust valve clearance.
    Di ko na alam kung sinu paniniwalaan ko. Bk po my nkxperience n n2, pls help nmn po...
    May 2012
    Di kaya head gasket or valve seal sir? We had this problem sa esi namin, mausok pag first start of the day then mawawala, kulang sa hatak and very rich yung exhaust fumes. Turns out na may problem sa head gasket and valve seal, hindi daw naka seat nag husto.
    pa-tune up mo ulit, sa ibang mekaniko naman. timing, advancer check, valve clearance. carb?
    serious! hindi lahat ng mekaniko ay magaling..
    Mechanic number 3 is an idiot. Hindi adjustable ang valve clearances ng GA series engines.
    First: Do a compression test to see if you engine is still running healthy.
    Second: Have your carburetor opened up and overhauled. Ensure that your jets are all OEM spec.
    Third: Check your engine timing
    Fourth: Replace your HT wires if these are the old ones pa
    Aug 2015
    mga tol, tulungan nyo rin ako sa problema ko sa nissan lec ko, nag change oil lang ako tas nilinisan ko spark plug, but upon starting up ayaw na mag stay running kotse ko, upon checking further patay dalawang spark plug ko or wlang reaction sa kotse if binubunot ko cap to diagnose if gumagana spark plug ko, pinalitan ko dalawang sp ko pero ganon prin, ang andar ng makina ay rough, and namamatay.
    Aug 2015
    mga toll, tulungan nyo rin ako sa problema ko sa nissan lec ko, nag change oil lang ako tas nilinisan ko spark plug, but upon starting up ayaw na mag stay running kotse ko, upon checking further patay dalawang spark plug ko or wlang reaction sa kotse if binubunot ko cap to diagnose if gumagana spark plug ko, pinalitan ko dalawang sp ko pero ganon prin, ang andar ng makina ay rough, and namamatay.
    ]- - - - - - - - - - - - - - - - - - - - - -[/COLOR]
    Quote Originally Posted by calib View Post
    nung tinanggal nyo ang sparking plugs, basa ba ng langis sila?
    kung OK pa naman ang sparking plugs nyo...
    baka sira ang hi tension cables... palitan mo kaya..?
    hiram ka nang kahit isa, at isa-isa mong palitan. pag gumanda ang takbo, ay malamang sira nga yung cable na pinalitan..
    dati, hard starting ang kotse ko... pag madilim ay nakikita kong dumadaloy ang kuryente sa hi tension cables ko... pinalitan ko sila at one click start na muli..
    good luck.
    Kung may usok ka na, piston or piston rings. Amoy gas, rich mixture, might be tagas or carb related. Barahan mo ng kamay yung intake tapos kung choke na or halos mamatay na makina, release. Do it mga 3 to 4 times. In my opinion your engine is due for an overhaul.
    Apr 2013
    Salamat sa tulong nyo mga boss. Itry ko po lahat ung mga sinabi nyo. Try ko po muna dun s head gasket or valve seal. Mgupdate po aq kung my pGbabago. Tnx..
    ako naman, during morning starts, medyo mausok pero when engine gets hot, ok na. mechanic told me its just possibly moisture since oil looks good and hindi naman daw nagbabawas.
Nissan Sentra LEC 94' 1.3 performance problem
