Results 1 to 13 of 13
    Quote Originally Posted by dwardov View Post
    Hello mga idol! Till now di pa rin nsosolve problm ng sentra ko. Mahina ang hatak, up to 110kph max speed lng. Pero ang main concern ko is ung mabahong amoy(amoy gas) inside and outside my car while engine is running. Minsan mausok sa unang start ng makina.malakas vibrate ng mkina.Habang hinahataw,lalong malakas amoy. Khit nkAC o hindi. Ngpalit n ko SP, inadjust n rin timing. Pti fuel/air mixture. Madami na tumingin na mechanic pero paiba-iba sila ng assesment. Mechanic1: need dw linisin carb..
    Mechanic2: bk dw faulty na ignition coil kea mhina sumunog.
    Mechanic3: itop overhaul,adjust valve clearance.
    Di ko na alam kung sinu paniniwalaan ko. Bk po my nkxperience n n2, pls help nmn po...
    Mechanic number 3 is an idiot. Hindi adjustable ang valve clearances ng GA series engines.
    First: Do a compression test to see if you engine is still running healthy.
    Second: Have your carburetor opened up and overhauled. Ensure that your jets are all OEM spec.
    Third: Check your engine timing
    Fourth: Replace your HT wires if these are the old ones pa
    Aug 2015
    mga tol, tulungan nyo rin ako sa problema ko sa nissan lec ko, nag change oil lang ako tas nilinisan ko spark plug, but upon starting up ayaw na mag stay running kotse ko, upon checking further patay dalawang spark plug ko or wlang reaction sa kotse if binubunot ko cap to diagnose if gumagana spark plug ko, pinalitan ko dalawang sp ko pero ganon prin, ang andar ng makina ay rough, and namamatay.
    Aug 2015
    mga toll, tulungan nyo rin ako sa problema ko sa nissan lec ko, nag change oil lang ako tas nilinisan ko spark plug, but upon starting up ayaw na mag stay running kotse ko, upon checking further patay dalawang spark plug ko or wlang reaction sa kotse if binubunot ko cap to diagnose if gumagana spark plug ko, pinalitan ko dalawang sp ko pero ganon prin, ang andar ng makina ay rough, and namamatay.
    ]- - - - - - - - - - - - - - - - - - - - - -[/COLOR]
    Quote Originally Posted by calib View Post
    nung tinanggal nyo ang sparking plugs, basa ba ng langis sila?
    kung OK pa naman ang sparking plugs nyo...
    baka sira ang hi tension cables... palitan mo kaya..?
    hiram ka nang kahit isa, at isa-isa mong palitan. pag gumanda ang takbo, ay malamang sira nga yung cable na pinalitan..
    dati, hard starting ang kotse ko... pag madilim ay nakikita kong dumadaloy ang kuryente sa hi tension cables ko... pinalitan ko sila at one click start na muli..
    good luck.
Nissan Sentra LEC 94' 1.3 performance problem
