Results 11 to 16 of 16
- Mar 2019
- 4
March 18th, 2019 06:26 PM #11Hi Sir,
Good Day. Nagawa na din po namin yung i-adjust ang menor. Pati adjustment sa Distributor nagawa na din namin. Pero ayaw na talaga tumino ng engine. Honestly, pati yung Talyer na pinapagawaan namin, sumasakit na ulo ng mga mekaniko dun. Kaya nag-iisip na ko palitan ng engine yun. Sa palagay ko, wala na din magkaka-interest na bilhin itong Nissan namin. Kaya naghahanap na lang ako ng paraan para mapatakbo itong car. May sentimental value na din kasi ito sa amin, dahil mga bata pa kami. Ito na ang service car namin.
- 54,202
March 19th, 2019 10:10 AM #12well, nissan did offer a diesel engine option in their box sentra in the late 80s...
kung suko na talaga kayo sa current engine niya... how's about getting a surplus gas engine? it was a popular model back then. it should be easier than hunting for that nissan diesel engine...
"sentimental value."
we shouldn't get too attached to the car.
it's potentially very expensive, even as it has absolutely no commercial value to someone else.Last edited by dr. d; March 19th, 2019 at 10:20 AM.
March 19th, 2019 10:36 AM #13
Sir, ganyan din problem ng B14 Super Saloon namin dati.
Nung una kapag inadjust yung distributor medyo tumitino, hanggang sa sumagad na sa adjustment.
Long story short, hiniram nya sa barkada niya (with the same car) yung distributor nung Sentra nila,
ayun, confirmed na distributor ang problema. Ended up buying a surplus unit, parang 2,500 yata
at that time. After mapalitan ayos na ulit.
Pa check mo din sir kung maayos yung pagka-timing nung makina after ma top-overhaul, kasi
nabanggit mo earlier mas lumala pa problema. baka sumablay ng isang "ipin" (gear) yung chain.
HTH
May 3rd, 2019 03:41 AM #14
- Sep 2013
- 168
May 14th, 2019 01:39 AM #15If you're really dead-on with an engine replacement to CD series, get a CD20 N/A for less headaches compared to a CD20T but expect it to perform similar to a CD17 with a little more grunt. Same lang ang mga turnilyuhan niyan for its engine support pero using a petrol-spec engine support set will result to vibrations during idle. And oh, get one which is already mated to a transmission because they use different flywheels and will be incompatible to your petrol engine's non-reduction type starter compared to a set which includes a diesel engine starter mated to the flywheel. Lipat mo na lang yung electronic speedometer sensor from your old tranny to the new one kasi cable type usually ang nasa CD20's pero pareho lang sila ng gear size at turnilyuhan.
There are parts available for CD20 believe it or not. Nissan released an AD-Max with the given engine locally. Stores also import parts because of imported diesel Serenas.
May 14th, 2019 10:36 PM #16
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
