Results 11 to 13 of 13
October 20th, 2012 10:35 AM #11
If there's a problem with the immobiliser, the security or CEL lamp would blink. Although it would probably show up when you hook it up with Nissan's Consult. I still think there may be a problem with one of the engine sensors.
IMO, immobilizers rarely conk out except if the chip inside the key went out of program which could easily be solved by re-progamming.
- Apr 2008
- 188
- Apr 2008
- 188
October 29th, 2012 12:47 AM #13[QUOTE=dr. d;2027093]is it possible to disconnect the immobilizer, so that the car can be used like any ordinary car...?[/Q
i think it could be by-passed using that same nissan program being used in ecu.. but ofcourse nissan won't disable a safety device, would you?
high idle RPM at engine start
