Results 1 to 8 of 8
    Apr 2009
    Guys help naman kung sino may idea on where to find a surplus MAF sensor. Sinubukan ng mekaniko na linisin without touching yung parang pinaka needle pero ganun pa din e. And paki advice ang price range na din if you don`t mind guys. Thank you.
    Quote Originally Posted by poknet View Post
    Cleaning of the sensor just requires a gentle but liberal spray of contact cleaner.
    Jun 2009
    Suggest you contact Mr. Orlan of Youngbros Auto Supply, Banaue, telephone number 732-46-57. They still have stock of that sensor for SR 20DE engine (for Altima/ Serena). It is really difficult to find that kind of sensor both brand new and surplus in the market.
    Apr 2009
    Sir Tried this one already by using Redisol but it didn`t work.
    sir Nickriingen Thanks for the info kontakin ko sya ngayon.
    Jul 2003
    basically, you didn't tell us about what is wrong with your ride? why does the mechanic said that it is the MAF that is causing your ride's problem?
    Apr 2008
    good day mga sir, makikiride na lang ako sa thread, tanong ko lang kung pwede kaya yung MAF ng sr20det sa series 3? sira kasi maf ng series 3 ko, putol yung 2 thermistors, narerepair din kaya yun? sana may magreply, thanks!
    Quote Originally Posted by ryansc View Post
    No. From what I know, SR20DE uses a MAF sensor while GA16 engines use a MAP system.
    MAP http://en.wikipedia.org/wiki/MAP_sensor
    MAF http://en.wikipedia.org/wiki/Mass_flow_sensor
    Assuming I am wrong and the GA16 you have uses a MAF sensor, using one from a different engine will result in a wrong sensor value sent to the engine's ECU resulting in a irregular running engine. This can be corrected by using a AFC or programmable piggyback ECU but it would be more expensive than just finding the correct sensor.
    Apr 2009
    It's possible, may na meet ako kahapon sa talyer na naka series 3 na super touring na naka MAF sensor from sr20de. Ok naman daw wala naman daw problema(so far ).
Help about MAF sensor for SR20de
