Results 1 to 8 of 8
November 16th, 2009 06:17 AM #1
Guys help naman kung sino may idea on where to find a surplus MAF sensor. Sinubukan ng mekaniko na linisin without touching yung parang pinaka needle pero ganun pa din e. And paki advice ang price range na din if you don`t mind guys. Thank you.
November 16th, 2009 02:02 PM #2
- Jun 2009
- 325
November 16th, 2009 03:29 PM #3
Suggest you contact Mr. Orlan of Youngbros Auto Supply, Banaue, telephone number 732-46-57. They still have stock of that sensor for SR 20DE engine (for Altima/ Serena). It is really difficult to find that kind of sensor both brand new and surplus in the market.
November 17th, 2009 05:41 AM #4
- Jul 2003
- 573
November 23rd, 2009 08:08 PM #5basically, you didn't tell us about what is wrong with your ride? why does the mechanic said that it is the MAF that is causing your ride's problem?
- Apr 2008
- 25
November 28th, 2009 06:15 PM #6good day mga sir, makikiride na lang ako sa thread, tanong ko lang kung pwede kaya yung MAF ng sr20det sa series 3? sira kasi maf ng series 3 ko, putol yung 2 thermistors, narerepair din kaya yun? sana may magreply, thanks!
November 28th, 2009 07:27 PM #7
No. From what I know, SR20DE uses a MAF sensor while GA16 engines use a MAP system.
MAP http://en.wikipedia.org/wiki/MAP_sensor
MAF http://en.wikipedia.org/wiki/Mass_flow_sensor
Assuming I am wrong and the GA16 you have uses a MAF sensor, using one from a different engine will result in a wrong sensor value sent to the engine's ECU resulting in a irregular running engine. This can be corrected by using a AFC or programmable piggyback ECU but it would be more expensive than just finding the correct sensor.
November 29th, 2009 08:54 PM #8
Eh ngayon BBM has just ordered the suspension of the fining of ebikes and calls for a grace period...
E-bike / E-trike ban details released by MMDA
