Results 1 to 8 of 8
- Apr 2008
- 5
April 11th, 2008 10:52 AM #1tumataas po ang idling kapag inaapakan ang preno... at nataas din ang idling after driving for several kilometers.. parati na lang ako nag aadjust ng idling.. please advise what to do... kulang sa budget eh para ipasok sa autoshop, maybe you can help me
- Jan 2008
- 154
April 11th, 2008 02:55 PM #3
Pag mainit na yun makina, at mataas yun idle, try to open the choke housing to check kung bumitaw yun choke mo. Tandaan mo nalang yun position ng choke housing before you remove it so you can put it back in the correct position. Kung di bumitaw yun choke mo, madumi lang yun carb. Try to clean the carb inside and out using carb cleaner. Then warm up the engine to check kung bumibitaw na yun choke. Pag ok na, adjust ka util para sa tamang idle setting.
Dapat di na tumaas yun idle pag mainit yun makita.
Kung tumataas pa rin yun idle pag nagbreak ka check for leaks or possible air in your break line?Last edited by zman; April 11th, 2008 at 02:57 PM.
- Apr 2008
- 5
April 11th, 2008 03:39 PM #4mga bro salamat sa mga reply... try ko check... lakas kase sa gas mas lalo na sa traffic d ka makababa
- Jan 2008
- 152
June 3rd, 2008 12:55 PM #5check mo rin baka nasira na yung auto choke mo.
nangyari na sakin yan. lumakas yung idling ko tapos lakas ng konsumo ko ng gas.
- Aug 2010
- 4
August 17th, 2010 10:10 PM #6try mo tangalin carb check for air leaks sa flopper i encounter major problems on carb's.palinis mo is the best way.
October 4th, 2010 02:30 PM #7
mga sirs...i need your expert advise din..yung 94 lec ng brother ko pina overhaul sa cruven dahil sa may white smoke with water ang lumalabas sa exhaust pipe..sinabihan siya ng kailangan palitan pistons,gaskets,timing chain ang valves..ang ipinalit pang 1500 ng engine dahil wala na daw available na pang 1300 ..ayun lumakas konsumo sa gas..before overhaul..9-10 km/liter ngayon after overhaul naging 6-7 km/liter..tinanong namin kung bakit ganun..ang sabi nung service mechanic talaga daw ganun..siningil siya ng 40k..ang question ngayon niya..is there way na maibalik sa dati yung konsumo ng gas?...please help
- Jul 2010
- 166
October 16th, 2010 08:52 PM #840k? ang mahal yata nyan sir, pag white smoke alam ko cylinder head gasket lng ang pinapalitan, pero yung iba sya rin na bubuksan yung makina kya sinasabay na nila palitan yung ibang parts. parang nakakaasar na marinig sa mekaniko na pag may tinanong ka ang isasagot sa "talagang ganon".
high idle RPM at engine start
