Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 381
    http://tsikot.yehey.com/forums/showthread.php?t=52381
    try to visit that thread if you still haven't read it.
    After that, I have some replies for you below.
    Quote Originally Posted by ed10908 View Post
    Hi guys,
    I just want to ask for an advise regarding Nissan Cefiro '97.
    I saw an ad here at tsikot.com about the Cefiro and after having it seen and had it test drive, I was so impressed by the smooth driving on top of its classy and elegant style, hence, I made a downpayment to secure the purchase.
    **** mind sharing which one you bought?
    Since i'm going to pay the balance this end of month. I would want to ask if I really made a right decision.
    **** If you ask me, oo especially if you are comfort oriented and I am not saying this because I have one too.
    All my friends were telling me that to own such is "sakit ng ulo" because of the expensive gas. They told me that the average city driving consumption is only 5km/liter where 95 octane (CALTEX gold) must be used to preserve the engine from corroding.
    **** "sakit sa ulo" if the unit you purchased was poorly maintained; just like with any other brand/make. Yes, its true 95 octane ang kailangan niya. But personally, I prefer XCS....
    Secondly, mahal daw ang pyesa and tune up that would cost me P 50,000.
    **** uhm....if you ask me, it's just the same. You just have to know where to purchase them. I learned it the hard way. Regarding the tune up, sobrang exaggerated. Siguro 8k at most if you use OEM parts and Fully Synthetic oil... Breakdown pero but this is based on sa huling pagbili ko - sparkplug 3.6k (600/pc), Oil Filter (OEM)- 400, Mobil Fully Synthetic 2.5k. Now you might ask as to why those spark cost that much; dahil sa pagka-platinum nito. Yan ang original niya. Good thing with it is that you don't have to change it until 100,000kms but ako sa 50,000kms, nagpapalit na ako... or earlier kapag mas maluwag... around 20,000 or 30,000kms.
    Third, Wala daw pyesa sa mga ordinaryong talyer. Unlike Honda and Toyota which is readily available. My concern is that I'll be using this for provincial trip (QUEZON to MANILA) for my pamangkin's monthly check up at UST hospital
    **** Depende kung saang area ka...but you don't really have to buy it from the CASA....
    Fourth, can i convert the gas to LPG?????
    **** Yes but if you ask me, it is not advisable.....
    Pls give me feedback guys.
    Thanks
    Hi guys,
    Not really corroding but more from running rough. The engine runs well on high octane gasoline. V-power from shell is also an option.
    As for the higher fuel consumption, it is true if you are in city driving. For highway driving, it gives good fuel economy if you have a light foot on the accelerator pedal.
    Depends on the specific model you got. If it's the V6 cylinder engine, then it's really a big headache to simply change sparkplugs on that engine. It would require removing the intake manifold to access the sparkplugs for regular replacement. Some people prefer to install platinum or irridium sparkplugs to lengthen the servicing intervals.
    As for parts, depends but generally luxury sedan parts are a bit more expensive but not prohibitively expensive.
    You can find parts from authorized Nissan parts dealers like the one in Banawe or other areas. You can also find "replacement" parts for those non-critical stuff to lower the cost of repairs when needed.
    Generally, a good condition unit should be fine. Of course you will have to deal with the car's relative age and the wear & tear due to it.
    Yes you can. SGI kits are recommended but venturi kits have been also used to convert such cars to LPG.
    As mentioned earlier, V6 models can be a headache including LPG conversions using SGI kits. This means it will be more expensive to convert a V6 cefiro than a 4 cylinder model even if they use the exact same parts, simply because of the increased amount of labor to install the parts.
    As I remember, EROOM's demo car for their venturi-closed loop LPG kit is a cefiro with a v6 engine. GREENFUEL also has converted V6 cefiro to LPG but they do charge a bit more for extra labor.
    BTW, if you are serious about LPG conversion, you have to check on the locations of LPG refueling stations in your area of QUEZON.
    Jan 2003
    gh,
    the vq20 is just as easy to tune up like any other cars. the engine timing can only be adjusted at a nissan dealer via consult and the spark plugs at the rear bank can be replaced easily be removing the ignition coils.
    hammerofgod,
    watch out for oil leaks. when i got my cefiro, i thought it was just a minor leak but it was a major one pala. engine has to be pulled down to replace all the oil seals.
    ed10908,
    alternatively, you can use petron's e10. its compatible with the cefiro. 95+ octane, no tope, i get around 6-7km/liter city driving. also the recommended oil is 5w30 for improved fuel economy.
    i
    Oct 2008
    Quote Originally Posted by non-vtec View Post
    gh,
    hammerofgod,
    i
    thanks for the info. sir, magkano ba buying ng 98 cefiro? do you know anyone selling? meron kasi akong nakita sa bulletin 99 cefiro 240k pa. 100tkm tapos palit na daw ng timing chain.
    Oct 2008
    mga bro, i saw a 1997 cefiro already. may i ask what should i look or watch out for with this unit? its quite old na din kasi 11 years na. yung keys ba nito, may chip na din? sabi ng 2nd owner, isa lang daw susi nya.
    need some inputs guys.
    thanks in advance
    Sep 2004
    2 keys with chip. look for oil leaks and kalampag.walang namang special sa mechanical system ng cefiro.kung automatic hanap mo sa tingin ko alam mo na ang ichecheck mo.di ka naman kasi hahanap ng automatic kung di ka pa nakagamit. total kms driven of 100k-150k is not a problem as long as well maintained yung makina.
    Jan 2003
    buyers' market ngayon ang cefiro. you can get one for less than 200k. you said palit timing chain? the car might not be getting regular PMS.
    check din pala for idling problems. even the idle up should be working. ignition coils, MAF should be working as well. idle must be smooth. test drive the car. it shouldn't be sluggish. if it is the knock sensor might be busted. another added expense.
    anyway, cefiro owners, what do you think about the 18" 350Z rims on a cefiro? bagay kaya?
    Sep 2004
    trade-in price ng 98 and below cefiro ngayun is 150k.
    ok naman pero medyo sporty for me....
    try to check sa ads.. may isang Cefiro na naka-post na parang ganon yung mags na nakalagay e; para lang makita mo how it looks...
    Oct 2009
    hi guyz,
    good day!
    im just new here and i have a very very big problem with regards to my 1999 nissan cefiro. Due to the latest flood cause by "ondoy" nalubog yung car ko. baka my suggestion kayo kung san ko pwede ipagawa yung car na medyo cheap yung price. im located here in marikina.
    thanks!
    Apr 2008
    Hi guys,
    My car is nissan cefiro elite 2000 model.
    Since I had my both front wheel bearings, cv rubber boots, and brake pads replaced, I have this griding, squeaking and knocking (or I should say bone-breaking) noise when braking at slow speed.
    I took the car back to the shop several times. They regreased the connecting area of brake pads to the caliper, replaced stabilizer links and some bushing on lower control arms but no luck. This shop couldn't find the solution to this.
    I think that they messed up something while replacing the said parts.
    It drives me crazy. Any one knows this problem? I'm thinking of replacing the lower control arms. Will this help?
    Any one also knows reliable auto shop in ortigas area?
    (Casa may be the best solution but they asked way too much on this problem. Nissan casa said they have to replace stablizer and lower control arms all together to see if it help. and this will cost me more than 30k which I can't afford)
    Dec 2009
    if you see someone sells a black nissan cefiro with license plate ZAK 188, DONT BUY IT! that [COLOR=blue ! important][COLOR=blue ! important]car[/COLOR][/COLOR] hit and ran my old nissan car while moving along commonwealth avenue, quezon city on december 21, 2009 around 4:00am, filed a police report and verified with lto the owner's name (it owns by a big company) naka alarm na yan kotse baka maloko lang kayo..pasensya na sa spam
    Nov 2007
    help naman po baka may service manual kayo ng 1997 cefiro. pasend na lang po sa email ray_gun28*yahoo.com
    Sep 2011
    good am. ask ko lang if may marecommend kayong mechanic na pwedeng tumingin sa 2002 cefiro elite ko sa QC area? tnx
    May 2010
    Guys, buhayin ko lang thread na ito. Anyone who is familiar with the Cefiro line up from 1997-2007? Balak ko gumawa ng used car review ng 1997-2000 model. Anyone who can help? Thanks!
    Quote Originally Posted by myk384 View Post
    What info do you need exactly?
    Jan 2003
    ^Top Gear made a thorough review of the A32 Cefiro from 97-98 Model sometime in 2004 or 05.
    Anyway...buying a good condition Cefiro is hard to come by these days as the engine is prone to warping due to overheat. Its better if the seller agrees to bring it to a shop first, have it lifted, checked for leaks, check signs of previous overheating.
    Hello Cefiro users! I was checking out a 97 Cefiro AT V6 24v model and the owner told me upfront when we were about to test drive it that the car wont move on "D" initially but need to shift to "D1" for about 10mins before it can be shifted to "D" ! What's wrong with this unit? Also the tachometer needle moves erratic - up, down, 2000 to 3000 rpm. Any solutions? TIA!
    Nov 2011
    Bumili kami ng ganito dati dalawa 180K isa. Idk what year model pero binili namin ng mga year 2004. Ngaun nakatambak na lang. Sobrang bilis nito napapatakbo ni mama ko ng 200 dati kaso ngayon sira sira na. Hahaha. Imported lang ata nabili namin.
    Jun 2005
    check the battery first. kung drained, charge muna or replace.
    kung okay batt. check starter motor.
    get a new shop to fix your car
All about Nissan Cefiro [merged threads]
