Thank you as well OTEP,
Maybe I'm just over-reacting nga lang talaga with the Comp. Box thing. And your right, hindi ko pa naman nakikita umilaw yung "check engine" light. Sa tingin ko rin baka sa idling lang ang problema kase nangyayari lang naman yun usually pag nakafull-stop ako.
And yes, mukhang engine o transmission support issue nga yung inngay na nadidinig ko just as BlackSun mentioned.
Yung AC is last on my checklist talaga coz I have my doubts din about that.
Thanks again for your input mga chiefs
The Series 3 computer box is well protected from the elements (it's beside the accelerator pedal) and failures are rare. A failure will usually manifest with a check-engine-light on your instrument cluster.
You can have the box checked for good measure but I'd check more mechanical things like the idle controls (a maze of hoses and servos on the engine) that manage vehicle idling.
Also start with the fundamentals like new fluids and filters. A clogged fuel or air filter can cause stalling also.
The 'thud' could be an engine support or a transmission issue. Best to have it checked.
If the a/c blows cold to you, don't mind your mechanic.
