hi mga sirs, kaialnb po ba dapat pinapalitan yung tubo sa radiator? (kung ano man tawag dun yung goma na papunta sa makina) nasabugan na kasi dati ako ng ganun na hose kailan kaya dapat palitan? thanks
Kung papalitan mo radiator hose mo . Iyong silicone radiator hose ang bilin mo para ligtas ka na masabugan . Mahal nga lang pero sulit naman . Kung regular hose ayos naman kaya lang lagi mong Check .Alam mo naman ngayon karamihan ng replacement parts mas mura pero hindi maganda Quality.
2 indicators to check:
1) If the radiator hose is still SOFT, you're still good. Due to transfer of hot water, it hardens in time. When it does, have it replaced na; and
2) If the radiator hose is "SWOLLEN", then it's not long that it may just give in. As mentioned in #1, heat from the water that passes thru the hose result to this in time. A swollen hose is an indication that it's time to replace it.
Hope this helps.
