Results 1 to 20 of 52
    Sep 2006
    Hi everybody,
    I need a good mechanic or shop that specializes in 2001 Patrol Di. Ayaw kong dalin Patrol ko sa casa. The problem is loss of power sabay ng pagingay ng makina. Thanks.
    jhol
    did the Engine Check light up? does your patrol emit black smoke when accelerating? is yes, your MAF might need cleaning or it may already be busted. try to remove it and clean it using contact cleaner.
    The MAF (Mass Air Flow) Sensor seems to be a likely culprit as Boybi mentioned. Try having it cleaned by a knowledgeable mechanic with some contact cleaner ro maybe have the CASA do a check on it. It's located right after the airbox and you shouldnt touch the pin sensor as it is a sensitive part.
    galing talaga ng mga tsikoteers!
    pwede rin sa workshop to...
    Sep 2006
    Thanks Vinj and Boybi. I appreciate your help. Sadly, hindi MAF ang problem. Napilitan nakong dalhin sa casa. Fuel injection daw ang problema. Kailangang icalibrate. Nakakagulat ang presyo. P90t for the calibration only. Hindi pa kasama ang pagbaklas. Bosch lang daw ang pwedeng gumawa nun. Medyo masakit dahil 73t km pa lang ang mileage nun. I have the periodic maintenance works done religiously pa :-(
    ...ang mahal nga.
    Pwede naman i-calibrate iyan ng hindi sa casa. Or just ask the casa kung saan nila pinapadala ang units for calibration (malabo namang may sariling calibration equipment ang casa).
    Ang alam ko Central Diesel Q.C. at Betan Makati nakakapagcalibrate ng GU. Yung Denso din siguro (sa Caloocan). Sila ang medyo high-end calibration shops dito sa Metro Manila. Sino ba may gawa ng injection system ng Patrol?
    Sep 2006
    Galing nako Central Diesel, P90t sa kanila minus baklas/kabit. Bosch ang may gawa ng injection system ng Patrol. Magtatanong din ako sa Betan at Denso.
2001 PATROL TDI problem
