Results 1 to 14 of 14
    May 2005
    I saw this in Solar CH (International Auto Show). SE-R got a good feedback and also picked as GOOD midsize car during the commentators feedback on their BAD & GOOD cars in the show.
    engine specs:
    3.5-liter DOHC 24-valve V6 engine
    260 hp2 * 6,000 rpm
    251 lb-ft * 3,600 rpm
    Emissions — LEVII/Tier 2 Bin5
    Continuously Variable Valve Timing Control
    System (CVTCS)
    Variable Intake System
    Nissan Direct Ignition System
    Platinum-tipped spark plugs
    Electronic drive-by-wire throttle
    Drivetrain:
    Front engine/front-wheel drive
    6-speed short-throw manual transmission
    Brakes:
    12.6" Front vented disc/11.5" rear disc brakes
    4-wheel Anti-lock Braking System (ABS) with Brake
    Suspension & Steering:
    Front: Independent subframe-mounted strut-type
    Rear: Multi-link independent
    Front and rear stabilizer bars
    SE-R sport-tuned suspension — retuned struts/
    shocks, stiffer springs, and thicker front and rear stabilizer bars
    Engine-speed-sensitive power-assisted rack-and-pinion steering
    any other pics?... hard to see the car's shape from the angle of the picture above.
    May 2005
    here u go
    May 2005
    ito pa
    May 2005
    May 2005
    all pics is 2005 model but same specs ng 2006 model nong ni feature sa International Auto Show
    There's at least 1 silver Altima SE-R in our neighborhood. I know because its driver tailed me all the way from work (in my 06 Sonata V6) probably daring me to try something. He then proceeded to smoke me at the last stoplight before entering our neighborhood proper...... Oh well. I've always said that there's no shame in losing when I'm driving a Hyundai, esp a mommy-car.
    when will nissan phils. bring in cars like these. the yulon cars are sooooo ho-hum...
    Quote Originally Posted by ssaloon
    I guess never, since cars like the Altima were developed for the USDM market.
    By the way, the photos of the Altima basti08 posted is an all-new model. Its the 1st Nissan model to use the new "Nissan D-platform".
    The closest relative to the Altima that might be arriving soon is the facelifted Nissan Teana which uses the same FF-L platform as the previous gen(2002-2006) Altima.
    *The FF-L is also used by the slightly larger USDM Maxima.
    Nissan Teana
    more pics of the 2007 altima
2006 NISSAN Altima SE-R
