Originally Posted by
miked
Hello fellow tsikoteers!
I'm in the process of rebuilding a motorbike (honda dio) and got some questions for you. Got used to repair 4-bangers...This is my first time to do a bike. A bit slow at the first time.
1. Do i really need to use a flywheel puller or a simple general purpose puller will do? mas ok kung gagamit ka ng flywheel puller
2. Haven't seen yet the engine internals, does the connecting rod ride on ball bearings or bearing inserts/halves? ball bearing sa big end kaya kailangang dalhin sa machine shop kung papalitan ang con rod o kahit yung bearing lang ang sira
3. Does the crankshaft ride on ball bearings or halves too?Ball bearings din
4. How do i remove the 2 front wheel bearings? Tried with a socket and looks like I need a sliding hammer.Baka may spacer (steal pipe) sa pagitan ng 2 bearing,yun ang tamaan mo para matulak palabas ang bearing. Ganyan kasi kadalasan ang technique sa mga motorbikes
5. Do i need to buy a pistong ring installer/remover as well as the ring compression tools or does the "bare hands+pliers" would do? Maliliit mga rings nyan,di mo na kailangan ang installer.Ingat lang sa pagbuka at medyo madaling maputol
6. How to time the ignition? like position piston at TDC, etc...... CDI na yan,di na kailangang iretime
TIA
