Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 34
    Sep 2006
    Vinegar and water works for my windshield. Is this safe for paint too?
    Mar 2018
    I already bought 2 sachets of Turtle Wax "liquid rubbing compound". Sa weekend, start ko na magtanggal ng water marks sa mga glass panels. Hopefully effective naman ang nabili ko hehe.
    depende yan bro kung gaano kagrabe yun watermarks. kung watermarks over watermars, elevo na ginagamit ko. usually pag di kinaya ng 0000 wire sponge, tsaka ko na gagamitan ng elevo.
    May 2017
    hindi ba mas ok gawin yan if after the rainy season na? It's raining almost everyday...
    Mar 2018
    Quote Originally Posted by Shutterbug View Post
    Actually pang bawas lang muna sa namuo na watermarks. Critical kasi sa mga glass panels. After the rainy days mag aaply ulit ako until cleared na then I'll try using some brands mentioned here to sort of waterproof the glass panels.
    Mar 2018
    Nabasa ko nga yun Elevo watermark remover. Effective ba saka easy to apply? 299 per bottle yata ito. Yun Turtle Wax liquid rubbing compound na sachet nasa 34 pesos lang hehe. Kaya try ko muna ito since dati naman I have been using rubbing compound sa mga namuo na stains sa paint hehe.
    eto gawa ko sakin bro ..
    cool dried watermarks (di naarawan), wipe with clean wet MF (repeat if madumi talaga), then dry MF
    polish
    0000 steel wool
    elevo
    worst case, dala pasig na hehehe
    May bagong product si Ginnova, medyo mahal lang...
    New Product: Gtechniq W9 Water Spot Remover(SRP P750.00)
    - 100% Coating Safe
    - Dissolves and removes Salts
    - Trap and removes Metal Ions from Tap Water
    - Removes Silica Scale
    Hard water spots and silica scale will disappear from the exterior surface with ease. The formula works well on glass, where traditionally watermarks are exceptionally hard to remove.
    Available at Reflections Car Care ->> Gtechniq W9 Water Spot Remover - REFLECTIONS CAR CARE
    Application instructions
    Use after washing and drying your car
    Do not apply in direct sunlight
    Shake well and wear gloves
    Spray liberally onto a clean Gtechniq MF1 ZeroR Microfibre Buff Cloth, wipe onto an area no bigger than 20x20cm (8x8)
    Buff immediately with a clean MF1 cloth
    Repeat as necessary
    Re-wash your car after use
    Store in a cool, dry place
    Meron din dito nagpost na okay daw yung Mr. Squeaky, na nabibili sa FB...
    Mar 2018
    - 100% Coating Safe
    Repeat as necessary
    Thanks for the share. This is pricey nga lang.
    Sa rubbing compound magagamit din kasi sa body paint kaya mas all around usage ito. Lalo na sa running board after the rains.
    Pag rubbing compound sa body paint medyo harsh siya compared to swirl & scratch remover...
watermarks problem
