Or perhaps you can have your car buffed. Personally, I prefer avoiding having watermarks in the first place by not letting dried water spots stay too long. I wash or wipe-off as soon as possible. Just have precautions against possible swirl marks.
Agree, prevention is the key. Pero kung nariyan na ang mga stubborn marks, ginagamitan ko ng cleaner wax. Hindi natatanggal agad. Unti-unti mawawala din.
Hi mga Sirs, i have similar problems with my newly bought second hand car, and aside from water marks, how can i remove the stains (white spots). I used bird poops remover but to no avail. Appreciate any inputs.
meron aq dati fish tank na madaming stain mark, a friend suggested na gamitan ko ng oxalic acid then scrub with soft scotch brite (mas maganda yung used scotch brite para di makadagdag ng scratches) and it really worked. Take note na iwasan mabasa ng oxalic yun paint kasi di aq sure kung makakasama yun sa paint.
Wet sand at buffing lang yan. Palagyan mo ng Diamond Gloss sa Ziebart para di magka water mark at para madaling linisin.
Windshield ba may problema o yung paint? Labo naman picture. Pag yung water mark sa glass hard water nag cause nyan.
[QUOTE=Sayu;2777977]Tips naman kung paano remove watermarks. Pwede ba to maalis kapag sabihin ko sa mga nagcacarwash?
You can use Elevo Watermark remover. Usually available at Concorde shops which costs about Php 299 for a bottle. It comes with its own sponge as well. Very effective especially for stubborn watermarks.
Vinegar and water works for my windshield. Is this safe for paint too?
I already bought 2 sachets of Turtle Wax "liquid rubbing compound". Sa weekend, start ko na magtanggal ng water marks sa mga glass panels. Hopefully effective naman ang nabili ko hehe.
Nabasa ko nga yun Elevo watermark remover. Effective ba saka easy to apply? 299 per bottle yata ito. Yun Turtle Wax liquid rubbing compound na sachet nasa 34 pesos lang hehe. Kaya try ko muna ito since dati naman I have been using rubbing compound sa mga namuo na stains sa paint hehe.
May bagong product si Ginnova, medyo mahal lang...
New Product: Gtechniq W9 Water Spot Remover(SRP P750.00)
- 100% Coating Safe
- Dissolves and removes Salts
- Trap and removes Metal Ions from Tap Water
- Removes Silica Scale
Hard water spots and silica scale will disappear from the exterior surface with ease. The formula works well on glass, where traditionally watermarks are exceptionally hard to remove.
Available at Reflections Car Care ->> Gtechniq W9 Water Spot Remover - REFLECTIONS CAR CARE
Application instructions
Use after washing and drying your car
Do not apply in direct sunlight
Shake well and wear gloves
Spray liberally onto a clean Gtechniq MF1 ZeroR Microfibre Buff Cloth, wipe onto an area no bigger than 20x20cm (8”x8”)
Buff immediately with a clean MF1 cloth
Repeat as necessary
Re-wash your car after use
Store in a cool, dry place
Meron din dito nagpost na okay daw yung Mr. Squeaky, na nabibili sa FB...
