Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 65
    Dec 2009
    #41
    Quote Originally Posted by polemicducky View Post
    Sorry for reviving old thread. Tanong lang, marami kasi nagsasabi na kailangan linisin ang bird poop asap before it stains the paint.
    Pero what if natanggal mo na yung poop, and there's already a faint "map" or etching on the paint, may urgency pa rin ba na tanggalin yung etching itself (I dunno, by polish or rubbing compound)? Does it still progressively get worse? Or pwede hintayin until next detailing?
    Bird dungs are acidic, that caused the discoloration. If you have already cleared the dung then it wont deteriorate unless a fresh bird strike hits the same spot.
    So watch out for bird dung
    Sent from my GT-P3110 using Tsikot Forums mobile app
    Jul 2018
    #42
    Quote Originally Posted by chronicle View Post
    It wont get worse but you will be irked by it everytime you see it.
    Then I'll try not to worry about it for now haha. Will just watch out for these in the future, thanks!
    Nov 2014
    #43
    Quote Originally Posted by kai s. View Post
    Yes acidic nga.
    Even with regular waxing (Collinite 845) occasionally the bird bombs would still etch my paint. Like a deeper watermark. Needs a bit of cutting to remove.
    Curious pa rin ako though sa itsura nung pagtuklap kaya I was hoping for a photo. Clearcoat lang ba yung natanggal?
    The best way sa pagtanggal ng bird poo ay basain ang table napkin o tissue, tapos ipatong o ilagay sa bird poo.hayaan mo lang for about 10 mins at alisin ang tissue and BWALA,malambot na ang poo poo at puede mo nang punasan o i hose ng water....proven na iyan bro...
    Jul 2015
    #44
    Spray it with wd40...leave it for 5 mins then wipe dry
    Mar 2004
    #45
    Voila ... vwäˈlä ...
    #46
    remove the poop asap.
    but once it does its demolition job on the paintwork, there's nothing you can do anymore.
    if your clearcoat is thick, you might do some "vigorous simonizing", to remove the damaged surface and some of the clearcoat as well..
    #47
    What’s worse than bird poop is bird vomit. It rapidly eats into the paint, down to the primer if not removed as soon as possible. This is why i always bring a spray bottle of Microtex quick wash. I just spritz it & let it sit for a while. Easier than WD.
    Apr 2014
    #48
    Bat droppings are on the level of bird poo as well.
    i've started using turtle wax bug and tar remover for those damaging tree sap napalm bombs and nasty bird droppings . it's very effective on those paint contaminants even if they're already dried out and baked by the sun's unforgiving uv rays.
    the turtle wax bug and tar remover is also easy to lug around and store in your trunk. and since it's no longer sold in pressurized aerosol cans, there's no danger of it exploding inside your baggage area during those frying pan hot summer afternoons
    Turtle Wax Bug & Tar Remover - Turtle Wax
    finally meron ako kasama user ng b&t remover hehehe. it does leave an oily feel though. needs to be rinsed off imo.
    Arrrrgggghhhh.... i need to try this one..
    I watched the youtube, most of them use 2500-3000 wet sand paper and then use the buffering tool...
    Jul 2015
    #50
    Wd40 works wonders
bird poops under the sun, what to do?
