Results 11 to 17 of 17
- 34
April 7th, 2021 01:25 PM #11
- 54,213
April 7th, 2021 01:25 PM #12
- 34
April 7th, 2021 01:37 PM #13okay I just looked. The reservoir is behind the bumper below the left headlight. I think access to it requires removal of the fender liner.
This is fast becoming something beyond my DIY skills. haha. darnit.
- 54,213
April 7th, 2021 01:38 PM #14...thereon goes banawe...
i do hope it's only the fender liner that requires removal.
in some cars kasi, the entire bumper has to be brought down, to gain access to certain parts.
perhaps you can search google for instructions.
that may decide whether you do it DIY, or you employ the skills of the banawe boys...
some years back,
they did in 15 minutes,
what i could not do in 2 hours.Last edited by dr. d; April 7th, 2021 at 01:44 PM.
- Nov 2009
- 3,507
April 7th, 2021 02:08 PM #15Remove the front left tyre. (use steady jack or secondary support jack for safety)
Remove the front clips only of the fender liner.
If you know how to "hawi" the liner to access the thing then you don't need to remove the whole liner as they are plastics that returns to original position.
Shine some light to get a better look of the obvious(wire harness, connectors), and maybe use a multimeter to check the coil resistance of the pump motor or the input voltage when the switch is activated.
- 34
April 7th, 2021 04:28 PM #16
April 7th, 2021 04:30 PM #17
What I learned about changing the wiper motor is that upon changing the motor you will have to drain the reserve I mistakenly fill up my reserve with wiper fluid and ended up draining it upon replacement of the wiper motor.
Mayor Cayetano expressed that she is willing to cooperate naman daw (probably meaning she wants...
Makati Subway. Completion date: 2025
