Originally Posted by
userfriendly
1. Pa check mo kung tama ang torque ng bolts sa head gasket.
- That'd be a big possibility problema lang is hindi ko alam kung ano ang pinaka mataas na torque ng engine ko.. Last time ng nag change kami ng head gasket 100 yata yung nka indicate sa torque..
2. Overhauling a radiator is not a sure thing. pag bulok na ang radiator it wont help. This is what happened to my old Kia Ceres. Temp rises even after radiator overhual. I replaced it with a new radiator and no more problems.
- I was there when my rad was overhauled and ok pa naman malinis na malinis pa nga sabi nga nag overhaul..
3. Do you still have a thermosat? It may be stuck. Easy way to check is hold your upper radiator hose when engine is warm. It should be hot. If its cold you have a stuck t-stat.
- This I dont know and I'll try to check on this..
4. A loose fan belt can also cause temp increase.
- I checked my fan belt and it needs to be changed since it already has cracks..
5. Check your radiator fans and relays. Check if they working properly.
- Rad fan is doing fine.. Automatic naman cya.. On and Off..
