Results 1 to 10 of 36
- Oct 2008
- 63
January 23rd, 2009 06:46 AM #1Hi guys need help here..
Ano po bah ang reason pag tumataas ang temp? I had my rad overhauled already.. Brand new din water pump ko.. Bagong palit head gasket ko.. Nag palit ako ng camshaft last week but pag tingin namin gastado na din yung shaft ng rocker arm.. Could this be the problem?? Hindi nka set yung clearance? Or kailangan na kasi palitan ng liner and piston ring.. Could it also be the culprit?? Pls help me.. Ito lang kasi ride ko and I have to drive my kid to school and fetch him also.. Ginagamit ko din ito sa business namin.. Your help will be very much appreciated.. Thanks po..
Tsikot Member Rank 4
- Jun 2006
- 2,605
January 23rd, 2009 09:09 AM #21. Pa check mo kung tama ang torque ng bolts sa head gasket.
2. Overhauling a radiator is not a sure thing. pag bulok na ang radiator it wont help. This is what happened to my old Kia Ceres. Temp rises even after radiator overhual. I replaced it with a new radiator and no more problems.
3. Do you still have a thermosat? It may be stuck. Easy way to check is hold your upper radiator hose when engine is warm. It should be hot. If its cold you have a stuck t-stat.
4. A loose fan belt can also cause temp increase.
5. Check your radiator fans and relays. Check if they working properly.
- Oct 2008
- 63
January 24th, 2009 08:50 AM #3
January 24th, 2009 10:31 AM #4
try to check also your radiator cap or better buy a new one yung fit talaga sa rad mo.may cap kasi na hindi tumama sa neck inside the radiator. check mo rin thermostat as sugested by fellow tsikoter. istoryans ka din no?
- Jan 2008
- 4,726
January 24th, 2009 11:33 AM #5check your cooling fan, baka masyado na dumudulas kaya hirap mag cool down ng radiator
- Oct 2008
- 63
January 27th, 2009 06:23 AM #6Ok po naman rad cap ko.. And my auxiliary is working fine.. Havent checked my thermostat though..
- Oct 2008
- 63
January 27th, 2009 07:25 AM #8
Check your temp sensor. Baka it's saying over heat pero normal naman ang temp ng engine mo.
- Oct 2008
- 63
January 30th, 2009 10:52 AM #10
na solve na ba? bro, afaik kung too advance yung timing madali uminit yung engine.correct me if am wrong fellow tsikoters...
