Results 1 to 10 of 24
- May 2010
- 78
February 25th, 2014 05:23 PM #1Hi all,
i'm currently canvassing for a Fully Synthetic Engine Oil for my Strada. I have been using Motul CRDI Specific but recently had issues with my EGR and emission. I think its because this oil isn't API CI-4 rated (designed for EGR).
To date, i have not found an FS engine oil that is both CI-4 rated and at the same time ACEA A3/B4 rated. A lot of users have been suggesting FS oils that are CI-4 rated but these are (usually) ACEA E4/E7/E9. A3/B4 is best for the Strada/Montero engines which are Direct Injection engines.
Is there any such Fully Synthetic oil that is both API CI-4 rated and ACEA A3/B4 rated? Thanks!!
P.S. there are a lot of Mineral oils that are rated as such, but i prefer to have FS for the best performance.
February 25th, 2014 06:01 PM #2
Sir ano naging problem sa emissions and EGR nyo? CRDI specific din gamit ko sa Montero and Santa Fe. No issues encountered so far.
- Aug 2003
- 317
February 25th, 2014 06:11 PM #3You can use a variety of oils for the Strada available in both fully syn, semi-syn and mineral as long as they are CI-4 or up. Hindi naman kailangan ng specific brand. But I do use Mobil 1 Turbo diesel truck on my Montero.
The emissions/EGR problem that plagues the Montero/Strada is usually the result of using diesel fuel from the big 3 which is only Euro II. Try using Euro IV diesel (available at Unioil and select Eastern Petroleum) and search on EGR blanking.
February 25th, 2014 06:42 PM #4
Manual says API or ACEA, not both. If you want to satisfy what Mitsubishi wants, then use Mitsubishi TurboXP.
- May 2010
- 78
February 25th, 2014 06:45 PM #5Pasang awa sa emission test ng LTO. and thats right after the 80k check up wherein oil filter, fuel filter and air filter was changed. CRDI specific oil and Petron Turbo diesel din ang gamit. With all of these, disappointing na pasang awa lang sa emission test.
when i called Diamond, sabi baka EGR ang problem. and when i researched, hindi designed for post-combustion technology (such as EGR) ang Motul CRDI specific. Its not CI-4 rated.
- May 2010
- 78
February 25th, 2014 06:56 PM #7
- May 2010
- 78
February 25th, 2014 06:58 PM #8
- Sep 2011
- 241
February 25th, 2014 11:50 PM #9This website might help you a bit :
Understanding engine oil designations | Motoring | RACQ
In a nut shell these 3 statements in the document can clear up things for you:
1. As stated API is for the Americans and ACEA is for the Europeans.
2. The document also tells us that
"ACEA standards recognise that European engines differ from US (style) engines in both their design and operating conditions and that the demands on their oils are also different. This requires the oils used in European engines to be unique and consequently, the classification system for them also needs to be unique. For this reason it is difficult to compare the common API classification and ACEA standards, as the test sequences for them are quite different."
3. and finally:
"While it is common for Japanese vehicle manufacturers to specify engine oils in terms of API oil service classifications, some applications use JASO ratings. This is because API rated oils are not always applicable to Japanese engines, due to variations in engine design and exhaust emission requirements compared to the American engines for which API oils were originally developed"
Its nice to find an FS oil that can satisfy what your looking for (do update us if you find one) but if you can't find one I think its safe to say that at the very least your FS oil should pass the API requirements of your rig since it is a Japanese engine unless it has a specific JASO ratings specs
- Apr 2011
- 109
February 26th, 2014 10:09 AM #10two things...first, as suggested, you can opt to use only what mitsubishi recommends which is turboxp. that is what i use for my glsv....second, find somebody who can have your car registered non apperance, and shall also provide smoke emmission test result for you...expect to pay extra though for the service...
