Results 1 to 10 of 21
- Jan 2007
- 173
May 29th, 2014 01:38 PM #1question about engine break... Nag caucause ba ito ng mas mabilis na wear and tear sa tranny and engine.
Sa manual kase it says better to use engine break than prolonge used of breaks or combination of both.
I usually go down sa parking from 7th floor of the parking building just in first gear, using 2nd gear sobeang bilis naman pag free wheel breaks naman. so perfect speed for me is just stay in 1st gear. I've been doing this for 2 years since nabili ko ung adventure ko.
May 29th, 2014 01:56 PM #2
^^^good job, tama yan sir. Mas safe at mas matipid sa gas. Ganyan din ako pagbumababa ng mataas na parking.
Posted via Tsikot Mobile App
May 29th, 2014 04:20 PM #3
*Brake not break ;)
Engine braking is useful for me...
Sent from my Nokia5110i-VgT using Tsikot Forums
- May 2014
- 118
May 29th, 2014 06:52 PM #4kala ko kanina break in yung topic , ganyan din driving habit ko, tipid sa gas and less gasgas sa gulong and brake pad
May 29th, 2014 07:04 PM #5
i believe engine brake is useful not only pag pababa, i do short engine brake din, pag curves, i keep my distance sa harap, then change 1 gear lower, causing a bit of brake ..... di na gagamit ng brakes, then, accelerate after the curve...... then quick change gear 1 higher.....
May 29th, 2014 08:18 PM #6
Question lang po... I talked to a mb mechanic fr. Abroad ang sabi nya yung mga modern diesel daw ngayon pag nag engine brake may auto shutoff ang fuel delivery... Is it true?
Sent from my C2305 using Tsikot Forums mobile app
- Jan 2014
- 655
May 29th, 2014 10:02 PM #8
I also do engine brake.
Meron nga ba bad effect ito and safe rpm for engine brake?
- Aug 2012
- 2,767
- May 2012
- 372
May 30th, 2014 01:49 AM #10
Yes Yes squeaking sound is heard when shifting only
