Results 1 to 2 of 2
- Jan 2009
- 16
September 22nd, 2009 05:12 AM #1Hi sa mga tsikoters! ask ko lang kung anong brand or appropriate power steering fluid ang maganda gamitin para sa 2009 Mitsubishi Lancer GLX CVT. napansin ko kasi na in between na ng min. and max. level yung fluid niya.
Ask ko narin na kung normal lang ba ito na mgbawas siya since 21 Thousand KMs * 8 months palang ang tinatalkbo ng car ko.
Thanks sa mga magrereply!! more power
September 22nd, 2009 08:18 AM #2
Try to put what is reccomended Power steering fluid on your owners manual on your Mitsubishi and its new. See if there DEXRON 111 . Then you can choose what brand of power sterring fluid available in the market. I use Castrol ATF TQ DEXRON 111 on my nissan . The atf fluid can also be use in powersteering fluid.
high idle RPM at engine start
