Results 1 to 10 of 14
Threaded View
Tsikot Member Rank 3
- Aug 2003
- 1,251
July 22nd, 2017 05:54 PM #1I have a 2010 Montero GLS non VGT A/T. Yung shudder is at start up, pag pinaandar ang makina, supposedly swabe ang pag andar. Ngayon, pa minsan minsan, may shudder o literally, "toog" na vibration. Pinatingin ko sa casa, ang tagal lumabas ang sakit, at paglabas, ang sagot nila, normal yan kasi meron din daw sa ibang montero, combustion shudder daw. Sabi ko, if its combustion, it should happen all the time, not once in a while. Tiningnan naman nila ang engine support, ok daw. I do not believe it is combustion, so ngayon pinatingin ko sa outside na shop. May inadjust sila sa bracket sa tambutso, pero andyan pa rin ang shudder.
After starting the car and the shudder happens, when I switch off the engine and restart, di na lalalabas ang problema and on a few occasions, lumabas, pero mahina na.
May naka experience na ba sa ganito?
A relative of mine in Canada had his Scion FR-S PPF'd and then had it ceramic coated. He says it's...
Ceramic Coating vs PPF (Paint Protection Film)
