Results 1 to 9 of 9
Tsikot Member Rank 4
- Feb 2004
- 1,704
July 27th, 2004 09:52 AM #1guys, i am trying to make it a habit to check the oil levels of my pajero gen 2 as often as possible. if the indicator shows that it is near the lower level already, how much oil should I add? i remember kasi doc diesel saying that di dapat naka lubog in oil when you take a look inside the oil cap. hangang saan lang dapat?
thanks,
andy
- Sep 2003
- 287
July 27th, 2004 10:15 AM #2best done using oil dip stick
dip stick is located on right (drivers side i.e. when seated on driver's seat its to your right inside the engine bay/compartment
to be done weekly before vehicle is driven or about 15 minutes after engine shut off
pull dipstick out
clean off with rag and reinsert
Note oil on end of dipstick
Add oil as necessaryto keep level between MAX and MIN marks on tip of dip stick or within hatched area of dipstick
source: HAYNES Pajero manual 1-9
July 27th, 2004 10:21 AM #3
the amount of oil between the MIN and MAX is approx 1L. so if you're in the halfway mark, you just add half a liter and your'e in full.
But of course the best method will be to add oil in small increments and monitor through the dipstick
- Feb 2004
- 1,704
July 27th, 2004 10:21 AM #4so i just gradually add oil and keep re-checking the dipstick? mag-reflect ba kaagad yan?
thanks,
andy
- Feb 2004
- 1,704
July 27th, 2004 10:44 AM #6thanks PK, sabay tayo nagreply, di ko pa nabasa entry mo. will do that before i go home at lunch.
nasa may 1/4 mark na kasi ako, dagdag una ako ng 1/2 liter
andy
- Jun 2004
- 476
July 27th, 2004 03:00 PM #7the best time to check the oil would be first thing in the morning. oil would have settled down overnight.
- Feb 2004
- 1,704
July 27th, 2004 03:28 PM #8thanks paj4x4. i checked it before going home for lunch (3 hours na hindi umaandar ang engine) and the level was fine. i will check again tomorrow morning.
andy
July 27th, 2004 05:03 PM #9
In general all your oil should be in the pan 30 minutes after engine shutdown
silver is my favorite color. i can get away with not cleaning the car for long-ish periods of time....
