Results 1,561 to 1,570 of 9388
March 5th, 2009 07:47 PM #1562
March 5th, 2009 11:03 PM #1563
I have a some shipment papunta diyan does any one want to add some order like bash plate for MS and Piggy Back System.
For the piggy back it is plug and play so if it is time for your PMS you can take it out and still have your warranty it can be installed and remove in less than 5 mins. Increase your HP and Torque, made in thailand for MS compatible with you ECU and other mods.
Pay the piggy back in full and you can use it for 5 days and have a money back guarantee if you din not like, give it is not damage specialy by water. Order Basis only.
March 6th, 2009 07:22 AM #1564
- Jun 2005
- 247
March 6th, 2009 09:03 AM #1565sir mic, nothing to worry re fc mo. take it for a longer steady drive, not just parking or frequent stops and gos. malakas talaga kain ng krudo pag ganon. also, pls take note that the fc reading on the multi-display is not as accurate as actual fc computation.
enjoy your ride sir! exciting eh noh! parang pag may bagong kasintahan....nasa honeymoon stage ka
March 6th, 2009 09:34 AM #1566
Question to MS owners, If i'm going to replace only one set of my headlamp (high or low beam) to HID, which do you think is better to replace the high or low beam? some says the low and some says high, in your (Montero opinion)
what do you think?
TIA
March 6th, 2009 10:28 AM #1568
March 6th, 2009 10:42 AM #1569
i suggest to change only your LOW. HID is very well suited for our projector type housing. besides the HIGH aim adjustment and reflector design is already sabog but very ideal so it will serve best its purpose. good for flashing and driving under very dark provincial and side streets
toronegro and kanuto goodluck! i'm sure marami pang kasunod at magkikita kita rin tayo.
gixxer_50, yes ganda ng seats mo, lapit lang rin ako sa Seatpro. will definitely go for that
March 6th, 2009 10:43 AM #1570
Hi sir! Question lang po baka may idea kayo. 1994 GLXi Lancer Itlog 4G92 - about 10yrs na rin na...
LANCER Itlog (93-96) Owners - Please Post Here!
