Results 21 to 30 of 43
- Nov 2009
- 3,482
September 27th, 2019 09:54 AM #21Generik socket may single at double kontak version baka wlapa P50, then bulb with the correct wattage. You need to re-splice at the harness, then kung walang ground, solder the housing with temp wire then tap to the nearest gnd. Then palitan monalang tail lamp assy kung sinipag kana pumunta autoshop banawi, get the cheapest Depo brand.
September 27th, 2019 10:00 AM #22
September 27th, 2019 10:01 AM #23
- 52,698
September 27th, 2019 10:07 AM #24
actually, all you need to succeed here, is enough anger to wreck and pull out that metal base!
keep trying. mapapagod ding yang metal base na yan.
and wd40 it liberally.
if you have protective leather gloves as well, use them. they will protect your hands.
and then,
after you succeed, you will see that the bulb socket is so badly corroded as well...
you will want to replace it!
heh heh heh.
joke lang po.
i am confident, that socket is still use-able. just make sure it won't get wet anymore.Last edited by dr. d; September 27th, 2019 at 10:16 AM.
- Nov 2009
- 3,482
September 27th, 2019 10:09 AM #25Yan ang mabilisan best option for me if di kinaya ng wd40 at wiggle it. Also try brake fluid or Turco rust eater using a syringe, just be careful no to make contact with the paint. Kung may heat gun or torch to loosen the rust, baka naman masunog ang plastic..
September 27th, 2019 11:57 AM #26
Hindi ba kaya ni bebe love kags?
Turco will make it stick harder
Check your manual..follow the bulb release instruction or do the reverse the bulb attach intruction
Sent from my SM-A520W using TapatalkLast edited by kisshmet; September 27th, 2019 at 11:59 AM.
September 27th, 2019 12:12 PM #27
Pahirapan mo pa sarili mo. Palitan mo na lang ng bagong socket. Tapos ang problena.
- 52,698
September 27th, 2019 11:00 PM #28to those who do not know how... or do not want to be bothered, yeah!
to those who know how to fix it... why?? kaya naman ayusin, ah.
September 28th, 2019 02:24 PM #29
dalhin mo na sakin LM
may double contact pako na narva
September 30th, 2019 10:11 AM #30
Salamat always ninj. Okay na.
I read about Rey's Auto Electrical in Marikina here and it turns out it's a 30 min drive on a transport strike Monday morning. And they open as early as 7:30am so dun nako nagpunta. Done in near 30 min, nagtagal lang kasi binutasan yung tail light assembly sa ilalim para daw pag pinasok ng tubig wag maipon, lumabas din. P180 labor, P50 for bulb P40 for socket (Stanley).
Thanks Tsikot
just seen a 10th gen cross 200,000 miles on reddit. is this a unicorn or has the cvt been proven...
All New 2016 Civic
