Page 118 of 162 FirstFirst ... 1868108114115116117118119120121122128 ... LastLast
Results 2,341 to 2,360 of 3240
    #2341
    Quote Originally Posted by DarkMatter View Post
    Sir zix ako din hindi nag sweetening nung 20k. Pushing 33K odo nako ngayon. Ilang liters ba required for sweetening?
    4 liters bro
    Quote Originally Posted by reinierinigo View Post
    Hi sir zixxx. How much po timing belt and rubber damper change. Montero 2010 thanks.
    pm sent sir
    Jan 2010
    #2342
    Sir pwede mong i-DIY yung sa transmission ATF sweetening, when I had still my montero, every 15k km sweetening ko..... just drain the atf, measure the quantity of ATF drained, then refill it through the dipstick port with the same volume of ATF drained.... when I bought the ATF from carworld san fernando, it's much cheaper....
    Mar 2015
    #2343
    Quote Originally Posted by rmsoriano View Post
    Noted sir, thanks. :thumbup:
    May 2013
    #2344
    sa manual na transmission po ba, ano mga ginagawa pag papalit ng oil? is it just a simple drain and refill or may mga special pa na gagawin?
    Sep 2009
    #2345
    Sir Vickoy, medyo matagal na itong post niyo pero ask ko lang kung sa Citimotors LP kayo nag pakabit ng Bosch horn? Magkano inabot?
    Doon din kasi ako nag papa-PMS since under warranty pa.
    Thanks.
    yup, so far ok naman malinaw yung oil tas i asked to look for the changed filter kasi nilagyan ko ng mark, tama naman. Nakakwentuhan ko yung SA and aware na daw sila sa ganung strategy kaya ang style ngayun, the mechanic must surrender the old filter bago sya isyuhan ng new...my bill is PhP 3,005.00.... kaso napamahal sa accs, nakursundahan ko pakabit ng hood guard, tv tuner and change the horn to bosch ;) astig na ngayun bumusina
    dami pala customer pag Sat dumating ako ng 8:30 am pang 28 na ko, lumabas unit ko mga 2pm...[/QUOTE]
    finally had my rig's power steering fluid and coolant flushed and changed today at home. bad trip lang iyong bagyo kasi ang lamig sa garahe
    i used oem coolant to be safe and a mag 1 decron III atf.
    Mar 2011
    #2347
    Sir Zix, pa pm po ng shop location. Thanks
    #2348
    rmsoriano, magkano ho bili nyo ng atf sa carworld san fernando?
    #2349
    baludoy, ilang gallon ho coolant nagamit nyo?
    Jul 2014
    #2350
    mga sir's sa mga nag PMS po ng 15k, how munch po? TIA
    #2351
    20k PMS
    Jul 2014
    #2352
    boss zix, if malapit lang ako sa shop mo dyan nko pa pms.. pinakamalapit sakin either san pablo or turbina. [emoji16]
    #2353
    Hi zix888, pls pm your contact info. Also include what is inluded in 70k km pms and cost. My unit is a 2009 montero 4x2 2.5 non vgt. Thanks.
    Quote Originally Posted by madelaine View Post
    i bought 8 liters of the stuff. kaso lang hindi naman lahat nagamit din
    #2355
    PMS
    *ZIX
    May 2013
    #2356
    mga boss magkano ba usually ang vic oil filter para sa monty natin?
    May 2005
    #2357
    Sir Zix, sent you a pm.
    Feb 2014
    #2358
    Quote Originally Posted by wyeshua View Post
    400-450 lang dito samin. vic c308
    Feb 2014
    #2359
    C306 pala sorry double post
    #2360
    Hi zix, pls pm your contact info. Also include cost & labor of timing belt, egr cleaning/blanking, optitron. My unit is a 2009 montero 4x2 2.5 non vgt. Thanks.
Montero Sport PMS Thread
