Results 1 to 10 of 10
- Dec 2006
- 43
November 6th, 2008 04:06 AM #1panu po mag reset kasi hindi po siya nag aautomatic lock door yung kusa naka steady na lang yung red light niya hindi na po siya nag bblink anu po kaya problem nun anu po ba kadalasan sira ng MMSS alarm ng mitsubishi
November 6th, 2008 08:21 AM #2
I think naka valet mode yun alarm niyo...just turn the ignition switch sa on position then switch off the toggle switch (usually located near the hood release lever sa lower left side) then turn on again the toggle switch (dapat yun red indicator mawala na pag on uli ng toggle switch) turn off ignition switch and try the alarm if its arming again....good luck.
- Dec 2006
- 43
November 6th, 2008 08:22 PM #3sir anu po ba yung vallet mode hindi nag chahange yung kulay ng red light eh it means sir sa ignition switch lang po ba yun para ma set yung alarm po ba
- Dec 2006
- 43
November 6th, 2008 08:37 PM #4sir gls sport po na unit 08 model eto po yung pag ka sunod sunod nung sa susi LOCK ACC ON START
November 7th, 2008 08:58 AM #5
Naka steady lang po yun red light sa indicator?....if so then naka valet mode ang alarm niyo po...ang gawin niyo po is switch the key sa ignition to on (hindi po kailangan naka start yun auto) tapos yun toggle switch dun sa ibaba malapit sa hood release ( bandang ibaba sa kaliwa karaniwang naka-install ito) switch off niyo po ito tapos on again ( wag niyo po ipihit ang susi mula sa on position) dapat mawala na ang red light dunsa indicator ng alarm sa dashboard, switch off ang ignition tapos try niyo po kun okey na ang alarm...good luck.
- Dec 2006
- 43
November 7th, 2008 09:29 AM #6sir ans yun ba yung may nkakabit na alarm sa ilalim tsinek ko po kasi parang may maliit na box
- Dec 2006
- 43
- Dec 2006
- 43
- Oct 2007
- 9
- Oct 2008
- 5
November 7th, 2008 03:43 PM #10pwede ba permanently disable yung alram alarm? hirap naman pag nagloko ayaw mag start.
Xiaomi E-Car
